      01-30-2023, 03:52 PM   #1
svho
Drives: X5
First oil change with this SUV
I just got the suv from the gf . It has 89K miles (2009 X5 3.0). I bought a Mobil oil filter at a local shop and saw two rubber rings and a crush(really small one) ring. What is that ring used at? I seen multiple videos where I don't see the that crush ring used.
Also, what is the size of the crush ring of the engine drain plug?
Thanks ahead,
TT
      01-30-2023, 07:24 PM   #2
JellyStyle
Builder of Special Cars
JellyStyle's Avatar
202
Drives: G12 B7,F02 750li,E70 X5M,E46M3
Location: Dallas, TX | Farmington, UT | Gainesville, FL
the crush is for the drain plug on the car.
the small o ring goes on the oil filter canister, the larger is for the canister seal. its pretty simple, use FCP Euro and do the oil exchange, free oil changes.. called Lifetime Replacement
      01-30-2023, 09:20 PM   #3
svho
Drives: X5
You are right, I couldn't believe such a small washer. I picked up some from Napa and the surface was a little wider than the one that came with the filter.
Small package comes in a big SUV
      01-31-2023, 02:57 PM   #4
Chrisnytx
Chrisnytx's Avatar
Drives: BMW X5
2013 BMW X5  [10.00]
I didn't realize you can actually exchange your oil at FCP
      01-31-2023, 04:47 PM   #5
JellyStyle
JellyStyle's Avatar
202
for a store credit, yes.. use Fedex ground or USPS flat rate if you can fit them in.
      02-24-2023, 06:08 PM   #6
Chrisnytx
Chrisnytx's Avatar
Drives: BMW X5
2013 BMW X5  [10.00]
Do you recommend sticking to the OEM BMW oil from FCP? Or would you use Liquid molly? and if so, which one would you use?
Thanks
      02-24-2023, 09:45 PM   #7
JellyStyle
JellyStyle's Avatar
202
Thanks
I use liquid moly, merely cause its popular and recommended, plus i can return it to FCP with their warranty.
      04-08-2023, 04:57 PM   #8
Chrisnytx
Chrisnytx's Avatar
Drives: BMW X5
2013 BMW X5  [10.00]
I just changed mine today! I used liquid moly liquid moly gen. I thought it was cool that it help identify leaks
