11-10-2014, 10:12 PM | #1 |
Rep 601
What size do you use for Winter Tires?
Hi everyone,
I have to put Winter Tires on my X5, but the original size for the 20" rims are: Front 275/40/R20 Rear 315/35/R20 But a lot of people put 275/40/R20 all around. Is it okay to put the same all around for Winter? What size do you put for Winter Setup? Thanks a lot!
- 2015 F85 BMW X5M = SOLD
- 2012 E70 BMW X5 35i - M Sport = SOLD - 2008 E71 BMW X6 35i - Sport Pack = SOLD - 2007 E70 BMW X5 4.8i - Sport Pack = SOLD - 2007 E70 BMW X5 30si - Sport Pack = SOLD |
11-11-2014, 06:09 PM | #2 |
Rep 601
somebody else? :O
11-11-2014, 06:19 PM | #3 |
Rep 65
I have 255 50 19 on all four on my 2012 X5M. I believe a narrow tire such as the 255 perform better in the snow. However, there are many here that have had good experience with wider winter tires. You will find a lot of information in many older threads in this forum and other X5 for mums such as Xoutpost and Bimmerfest. Searh winter tires, winter setup etc. Good luck.
11-11-2014, 06:22 PM | #4 |
Rep 828
Yes! I have 275 Pirelli Scorpions all around on my 20" rims (214s). The tires look a little stretched on the staggered rears, but that's how I bought them (slightly used). I haven't put them on my car yet (still holding out despite the inclement weather approaching).
11-11-2014, 06:44 PM | #5 |
Rep 1,292
255 50 19- 298M all four corners with Hakka R2 SUV.
_____________________________________ 2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4 |
11-11-2014, 08:16 PM | #6 |
Rep 601
Thank you all!
You don't have any problem to put the same size all around? Because OEM 19" size are: -255/50/19 front -285/45/19 rear and OEM 20" size are: -275/40/20 front -315/35/20 rear
11-11-2014, 08:42 PM | #7 |
Rep 828
Correct...Thus, my comment about using 275s all around for OEM 20" wheels. The rears are a bit stretched on the staggered. I haven't put them on yet, but don't expect to have a problem with them.
11-11-2014, 08:48 PM | #8 |
Rep 65
I believe the requirement is to have the front and rear circumference about the same. 275's = 90.0, 315's = 90.1. So no issues, with same tire if it fits otherwise. I have the identical setup as Denaliman. Really like the Nokian R2.
11-12-2014, 01:06 AM | #9 |
Rep 596
same wheels, same tires for winter
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option |
11-12-2014, 03:03 PM | #10 |
Rep 48
Re-Re-Repost from last winter:
Re-post from last winter... Having moved from FL to Kansas City at the start of winter, I learned very quickly the limitations of the stock RFTs in really cold and then snow. I had the following mounted on my OEM style 300 wheels: 2 275/40R-20 Pirelli Scorpion Ice & Snow Run Flat Run Flat XL $346.00 each 2 315/35R-20 Pirelli Scorpion Ice & Snow Run Flat Run Flat XL $412.00 each Wow - as much fun as the X5M is dry, having the power, AWD and true snow tires make it a true BLAST to drive in the cold and snow! I still wanted RFTs so I didn't have to worry about the no-spare-tire. Yes; expensive. Yes; worth every penny for safety, security and fun. I know not everyone is thrilled with RFTs nor the Pirelli's, but I'm thrilled with my set-up. |
11-12-2014, 03:35 PM | #11 |
Rep 104
I'm selling the 275 315 Pirellis Ice and snows that came with the vehicle and switching to the new studded Nokians SUV8 in 275 40 all around. As a couple of have mentioned, the rears will look a bit stretched, but it shouldn't be terrible.
11-15-2014, 10:49 PM | #12 |
Rep 588
I have 275/40/20 and 315/35/20 and the car works perfect in the snow.
http://www.xbimmers.com/forums/showthread.php?t=950209 |
