04-03-2017, 12:05 PM | #1 |
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
Pulling a Car Hauler
I will be moving from VA to WA state at the end of the year. I have. 13 X5 35i without a hitch but considering getting one. My reason is that I have my DD 328i and my e46 M3. So I will have to ship both but am thinking of hauling the m3. I feel that it would be safer. Has anyone made this trip before while pulling with their x5? Or do you have any recommendations for shipping? I would sell one but don't really want to. Thanks a lot.
2004 BMW M3
2013 BMW X5 35i 2008 BMW 335xi http://koloa.com/?afmc=8t |
04-03-2017, 12:42 PM | #2 |
Mporium BMW
3750
Rep 2,907
Drives: 2011 E93 M3
That's a really long haul, your X5 might have a hard time with that. Someone with experience car hauling in a 6 cylinder X5 might need to chime in with their first hand experience but I would be hesitant to strain your X5 with such a load cross country.
I use Uship a lot. You'd be looking at between $1300-$1500 to have a transporter ship the M3 on an open trailer. IMO that's a safer option. CERTAINLY a less stressful one. |
04-03-2017, 01:13 PM | #3 | |
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
2004 BMW M3
04-03-2017, 06:48 PM | #4 |
Rep 1,044
I would echo deansbimmer especially since you don't have a hitch already. If you considered the cost of everything you'd probably break even or save little for a lot of headache.
Check out Montway Auto Transport. I used them when I relocated from CA to TX and they were awesome. |
04-05-2017, 06:47 AM | #5 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
I tow with my x5 all the time, have done thousands of miles with my 4.8i and soon like next weekend with my x5 m. There is a good thread about it https://xoutpost.com/bmw-sav-forums/...l-economy.html
So some things to consider. You'll need a hitch and probably a trailer brake system for your X5. Most states require trailer brakes if your towing more than 3500lbs(which is a good idea anyway) Which you will be at with car and trailer. The BMW hitch installed if you shop around is about 1100. Which should include coding to active tow haul mode, backup camera hitch alignment (nice), disables rear parking sensors when attached to a trailer, and activates anti sway. The brake controller is 75-300. So tp just get ready to tow your looking at a minimum of 500 if you diy the hitch and skip the coding, to 1400 if you pay for install. The second thing to consider is your fuel economy will be a lot lower while towing. I'd expect your car to get between 8-14mpg while towing. So your trip will be at least 2x the fuel of driving solo. I think the 35i is just fine for towing, it's got about the same amount of power as the 48i, but better low speed torque. BMW built a great cooling system too to handle towing. You'll be fine. It just won't save you any money to add a hitch and get bad gas mileage vs shipping. I'd only do it if you plan to tow in the future. |
04-05-2017, 02:21 PM | #6 | |
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
2004 BMW M3
04-07-2017, 05:28 AM | #7 |
Rep 937
Yea our drive shafts and trannies r too sensitive for that much weight, for that long. Maybe in town it will do. What you can do is rent a uhaul with a tow dolly and tow it.
04-07-2017, 07:36 AM | #8 |
Rep 1,044
04-07-2017, 07:52 AM | #9 |
Rep 1,544
Drives: '22 Tesla MY + '23 Tesla MY
WAT?
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
04-07-2017, 10:50 AM | #11 |
Rep 728
OP, have you ever towed before? It can be a difficult task if you've never done it before, especially with a smaller truck/SUV. The X5 has a 6000lb tow capacity but think about the hitch also and reference the link below for info. Separately, Trailer from uhaul is usually 2200lbs and the car is 3400 lbs so you are right at the limit. The X5 is like 5300 lbs. towing over your vehicles weight at highway speeds can be a little challenging. You 100% need the trailer brakes hooked up. Think about safety before deciding it's not worth transportation costs.
Personally, if it were me and under maybe 800 miles I'd probably give it a whirl provided that my hitch held the weight. All the hitches I looked up for our trucks maxed out at 5000lbs though. Link for info about actual max load: https://www.doubledtrailers.com/dang...a-safe-weight/ |
04-07-2017, 11:42 AM | #12 |
Rep 1,579
I have towed a short 1500 lb cargo trailer cross country twice. I would never go cross country with anything bigger. Parking hassle, stopping for gas every 200 miles, doing the speed limit makes for a more tiring trip.
If you can, try to make a vacation out of it. Doing it in 4 days is not nearly as fun or meaningful. There is some pretty country out west. |
04-07-2017, 12:00 PM | #13 |
Rep 728
Also, is your M3 lowered? I towed my E46 M3 that had H&R lowering springs on it with a full sized Uhaul. It took a lot of wood and patience to get the lowered car up the ramp. When I got to the new house I decided to cut that out and found a parking lot higher than the adjacent road. I backed the trailer up to the curb, set the ramps down on the curb and backed the car out onto the curb which was level with the parking lot. I blocked traffic for a few minutes but faster than the two hour wood ordeal in the pouring rain.
04-07-2017, 01:11 PM | #14 |
Rep 18
I just came back from a 7 hour trip each way, towing a 2 place enclosed snowmobile trailer with 2 sleds in it. I figure it was close to 2000 pounds.
My 2013 35i did not know anything was back there, usually 23 MPG on the highway with the trailer 19MPG and that's at 70 - 80 MPH. The vehicle drove great, like nothing was behind me. I don't think I would want to pull anything close to max weight but I work at a local race track and see numerous BMW Club member's using X5 35i's coming in from 2 -3 hours away pulling their track cars and equipment. FWIW |
04-07-2017, 07:21 PM | #15 | |
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
2004 BMW M3
04-07-2017, 07:23 PM | #16 | |
Rep 426
Drives: 2004 BMW M3
2020 BMW X3M COMP
2004 BMW M3
04-08-2017, 07:29 AM | #17 | |
Mporium BMW
3750
Rep 2,907
Drives: 2011 E93 M3
IMO your best option is to pay for transport. |
