12-25-2013, 06:13 PM | #2 |
Abjm3
Rep 132
Best tires
There are other tires sizes you can go with, but if you have a staggered set, go with 295/30-22 & 335/25-22. If not staggered go with 285/35-22 all around. Hope this helps or points you in the right direction.
12-25-2013, 08:56 PM | #3 |
Passes everything but the gas station
49
Rep 795
Like last post said those tire options. And as far as manufacturers go. Well Pirelli is almost exclusively your only option.
Disappointing unless you live in a location where weather is nice 365 then these will suffice. Not great in performance but not the worst either. |
12-25-2013, 09:38 PM | #4 |
Rep 69
Hi, quick question. Why not go with 295/30-22 if not staggered? Not following why you recommend the narrower 285 width on a non staggered set up.
GB
07 328i e93 Alpine White 10 4.8 e70 Titanium Silver M Sport |
12-25-2013, 10:21 PM | #5 |
Vanilla Gorrilla
31
Rep 610
I have 22" Yokohama advans that are an option but the fronts are 265mm and rear are 315mm I would have to look to see the aspect ratio but they are close to stock overall dimensions.
In square 285/35 I know Nitto makes a couple options, if I did it again I think I would go with Pirelli just because of the sizes...the Advans are a way better tire but the sizes are not the best 10" is about as wide of wheel as you could go in the front so if you stuck with a 22x10/22x11 they are a superior tire.
X5M, Eisenmann exhaust, 22" HRE wheels, catless down pipes, Stage II tune/X5 Diesel, Lowered & Tuned
12-25-2013, 10:52 PM | #6 |
Rep 36
Now what if you wanted to go with a taller side wall. I know it would be slightly bigger diameter then stock. Just thinking it may be more comfortable ride. Any suggestions on that?
