      12-18-2011, 01:14 PM   #1
baby huey
Drives: 2013 X5M
Tire Pressure
Owner's Manual for X5M gives an OE range of 33 to 38 psi for RFT's, depending on speed driven. Any personal experiences and recommendations regarding daily use pressure.
      12-18-2011, 06:11 PM   #2
263464757
Lt. General
263464757's Avatar
Drives: X5 5.0, 540i, 1965 C2
I run 44 on the front and 46 on the rear.
I have always set my tire press at 5 to 6 lbs. under the max rating on the tire, not what the manufacture says. This comes from years of putting various tire's through the paces on a hot summer day and checking the tire press before and after.
The most gain that I ever had was 6 psi from a 70 degree garage floor temp to 90 degree day with 30 minute's of running the tire to the edge of it's envelope.
Now that I run nitrogen, I get little if any rise in press.
My current tires (Conti DWS), will probably be the first set that will nowhere near go's to the expected mileage of 50K. I am wearing the inside edge on the rears 2 to 1 with just 12,000 miles...very disappointing!
Seems ya just cannot get away from the negative camber in the rear, a factor that seems to be exaggerated with 20" 315 rear! ....."or 325's in your case"
I run non-RFT.
