      05-27-2023, 07:08 PM   #1
e70goboom
Drives: bmw x5 e70
Exclamation Is my engine dead? E70 x5 35d
Hi, I'm new here. I'm a noob when it comes to car maintenance and all that. Could you guys help identify what the possible issues with my car are? All i know is i'm burning a ton of oil. Maybe head gasket is blown? Car is 2009 x5 35d
No leaks, no strange noises just a ton of smoke.
Blue smoke from both exhaust and engine.
https://youtube.com/shorts/-40tsFNoQf4?feature=share
https://youtube.com/shorts/bYRWzeEqp4w?feature=share
I know this will most likely be an expensive fix so I'm just trying to get an idea of to expect if I tow it to a shop, or if i should give it a stab of my own.
Other known issues: DPF has needed changing for over 2 years. Maybe it got clogged to the point the back pressure blew the engine?
Last edited by e70goboom; 05-27-2023 at 07:20 PM.. Reason: adding more information.
      05-27-2023, 07:13 PM   #2
RL18
Drives: 2011 335d sport
What were you doing when it started doing that?
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R.
      05-27-2023, 07:14 PM   #3
e70goboom
Drives: bmw x5 e70
Just driving back from the gym when i noticed it start smoking. Kind of ignored it but the next morning driving to work i could see this plume of smoke coming from the engine and the exhausts so i pulled over and towed it back home.
      05-27-2023, 09:24 PM   #4
RL18
Were you doing a pull when it happened or normal driving?
If you were doing a pulling could be a turbo or vcg. I doubt it’s a head gasket not a common issue, plus smoke would be white. If it’s blue you’re burning oil, so I’d check the small turbo out since it’s the easiest to get to. If it looks alright and you don’t see any leaks around it or play in the shaft then you could pull into intake and check around the vcg to see if you got oil seeping on the sides (although you don’t have to pull the intake manifold to look there but it makes it easier
What’s the mileage btw?
      05-28-2023, 09:17 PM   #5
e70goboom
Drives: bmw x5 e70
normal driving. odometer is around 230 000 km.
      05-29-2023, 03:22 PM   #6
RL18
Is it stock?
Check your small turbo. Just need to remove the air intake where it goes into the turbo inlet
      05-30-2023, 07:12 PM   #7
wcs531
Drives: E90 335xi / E70 X5d
Engine idle sounds fine which is good, my money would definitely be on a bad turbo.
      06-25-2023, 10:15 PM   #8
e70goboom
Drives: bmw x5 e70
engine codes as follows
P244a
p14a6
p2457
p02cb
p2201
p0471
p203a
p2297
p323f
p0402
p0299
p14d0
p042a
p14a6
p2a00
      06-26-2023, 11:33 AM   #9
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
Get setup with a better way to scan for codes. INPA, or ISTA, or Bimmercode. Something that will give more specific BMW codes. Generic P codes are pretty useless on BMWs.
