12-25-2022, 10:29 PM | #1 |
Rep 30
High mileage x5m?
Hi guys,I'm new here and I'm looking into getting a cheaper high mileage x5m. I was wondering if there are any guys with over 150k miles here? And if so what issues have you had/ it are having?
12-28-2022, 01:15 PM | #2 |
Oil Dispenser
60
Rep 77
Do not buy, you would want a much lower mileage one to keep up with maintence costs and repairs. A high mileage one would most likely have overdue services that need attention. Things that fail often that cost a lot are:
Rod bearings Injectors Cracked coolant pipes Oil leaks (given) |
12-28-2022, 05:54 PM | #3 | |
Rep 30
12-28-2022, 06:58 PM | #5 |
Rep 60
I'm at 143,000 on my 2010 X5M. Owned it CPO'ed since 2012 with 13,000 miles. Have gone through all the major recals/TSBs (injectors, fuel pumps, back up camera harness). I've also gone through several Filtered Air Duct crank case hoses. Recently just tackled turbo coolant lines, coolant y-pipe, turbo oil return lines and housing, auxiliary turbo coolant pumps, vacuum pump (oil leak), spark plugs, coils, fuel tank breather line, lower oil pan gasket with oil pump chain adjustment (was very loose), both rear suspension air bags, full front suspenion bushing and ball joint over haul, shock and spring mounts and perches with Dinan Spring install, transfer case output shaft seal and o-ring, Guibo Flex disc, and, transfer case actuator gears, transfer case mount bushing, starter, emergency brake actuator, wheel bearings with f85 front rotors and pads, just to list a few....
Still need to tackle some major oil leaks... most likely valve cover gaskets and valve stem seals, upper oil pan gasket and potentially rod bearings while in there, rear differential is also leaking. But overall it's an awesome car! Last edited by GregWX5; 12-28-2022 at 07:30 PM.. |
12-29-2022, 10:13 PM | #6 | |
Rep 30
12-31-2022, 07:03 PM | #7 | |
Rep 267
Drives: 2006 Z4 M Roadster
If you’re not mechanically skilled, don’t have the standard BMW software tools and don’t work or or want to learn to work on your own vehicle then stay away. These trucks are not hands off
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic 2012 X5 M - Monte Carlo Blue Metallic 2017 X1 xDrive28i - Alpine White |
01-01-2023, 10:06 PM | #8 | |
Rep 30
01-02-2023, 06:51 PM | #9 |
Rep 1,564
185K Miles N63 modded (bolt-ons, custom intake), & tuned to 600hp checking in. (internally the n63 is identical to the s63 minus the upgrades the S63 gets such as forged pistons, better exhaust cam, & more oil sprayers).
The s63/n63 platform is a complex beast. However as SpaceGray just mentioned, if you take care of it, you can easily get 200K+ miles out of it without rebuild (Liqui Moly or better 5-40 oil + 2 cans Mos2 additive every 5K low temp thermostat, install catch cans, ditch the engine cover, open the hood when you park) Not only can you get high miles out of it with these simple mods, you will still be just as fast a new X5M running sub 4 second 0-60 times & mid to high 11's 1/4 miles (see receipts below). Not to many 180k+ mile 10 year old 5400lb SUV's can lay claim to that, so say what you will about this platform, it is a beast when treated right. Proper oil changes & Heat Management is the key here, it destroys everything under the hood so keeping your engine cool is critical. Parking with the hood closed after along stretch of stop and go traffic is what kills all of those complex plastic & rubber bits under the hood. Also recommend mixing in 3-4 gals of E85 with every tank to keep the LSPI demons at bay. Last edited by Sophisticated Redneck; 01-02-2023 at 07:53 PM.. |
argento538.00 |
01-02-2023, 07:41 PM | #10 |
Rep 30
I really appreciate the last 2 post. The catch can setup makes complete sense. And I was hoping if I bought a good running higher milage one that I could do catch up maintenance and keep it running strong.
01-03-2023, 03:24 PM | #11 | |
Rep 265
Thanks
IG @E70_XRatedM | YT: E70M Garage
01-03-2023, 06:18 PM | #12 | |
Rep 1,564
Vastly improved oil control (no more oil leaks above the oil line) Increased Fuel & Water Flash (fuel/water evaporates much more quickly from the oil at this reduced crankcase pressure). Less oil burning through the valve stem seals. This setup is unique to the E70 N63/S63 only. They did away with the lower intake vacuum taps on the later gens. |
XRatedM138.50 |
01-27-2023, 05:21 AM | #13 |
Rep 30
My wife and I went ahead and bought a used x5m. We flew from VA to Florida to but it. And we were actually able to buy one with less miles than I originally thought for our budget. Our car had 125k when we picked it up. I feel like the price was good. 12k
We drove a little over 1000miles home without surprise issues. We bought it knowing the traction control light was on. Got home and checked everything over. The next day I did a few dragy 0-60 test as a baseline before I started maintenance and performance work. 4.59 secs isn't to bad all stock. It was a fun trip we are excited to own it and my wife likes it so much she's excited to restore it back to original condition! |
