TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Is it necessary to drain the coolant when changing OFHG?
      04-25-2024, 07:17 AM   #1
suspect
27
Drives: car
Is it necessary to drain the coolant when doing OFHG replacement? I’ve read about siphoning it out of the coolant reservoir so that the coolant level sits lower than the OFH. What happens if you don’t bother? Does it pour out of the OFH when you open it?
      04-25-2024, 09:32 AM   #2
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
I believe that you should siphon a little out of the reservoir or it will make a bit of a mess, I'd checkout Zeitens YouTube channel to confirm it's a great resource. Just take a turkey baster and pull about a liter out and return when finished.
      04-25-2024, 12:14 PM   #3
jadams161
jadams161's Avatar
Drives: 2009 E93 335i. 2011 E90 328xi
No, it is not needed. When you pull the upper rad hose to the OFH it drains out what is needed. Remember to replace the "mickey mouse" flange while in there. Use real BMW gaskets and coolant.
feuer4277.00
      04-28-2024, 02:47 PM   #4
suspect
27
Drives: car
Thanks guys. Taking a litre out of the expansion/reservoir was enough. Engine head flange (mickey mouse) already replaced.
A tip that helped was breaking the OFH bolt loose next to this flange using E10 spanner and then using a 12 point 8mm spanner to undo the rest of the bolt. Or use a E10 ratchet spanner if you can find one.
      05-02-2024, 07:33 PM   #5
feuer
feuer's Avatar
Drives: wife crazy!
Very accurate!
