BMW 3-Series (E90 E92) Forum
What is a good milage to expect my n52 2009 328xi to be solid?
04-05-2024, 10:55 AM | #1 |
Rep 30
Drives: Bmw 328xi
Until what milege I can expect it to be a good daily? It has 190km now, got it at 185km. Oil change anf filter every 5-7km. And I don't mind investing in it time to time trying to keep it in good condition , what can I expect from it? 250km? 300km? 200km;(?
04-05-2024, 11:42 AM | #2 |
Rep 502
At this point these cars are so old and cheap, you might as well think of it as driving a $7000 BMW for a couple of years as opposed to dishing out $60k for a new one. Instead of "paying" depreciation over the years, you have straight up operating costs to keep it on the road.
I bought my E90 330xi 6 speed msport for 7k with a fat stack of receipts at 190k km. Mostly for fluids, suspension refresh, random electrical issues over the years. I've already put in $6k in parts/tires to get it where I want to be and not leave me stranded. Some of the costs were associated with oddball things like broken CV axle which was $500, a cracked magnesium valve cover ($450) due to corrosion, and I paid a mechanic to replace four broken off aluminum headbolts by the timing cover which most people do not do. Scan your car regularly to keep an eye on what's going on. |
bimmer328xi9.00 |
04-05-2024, 12:13 PM | #3 |
Rep 1,560
n52 I would say around 300k km, assuming water pump and seal changed.
Then other stuff will start to fail : a/c compressor, power steering pump, crank shaft seals. Depends how far you want to go. I can imagine a N52 with 1M km if no winter and everything has been replaced many times. regular oil change. There's few topics here ''300k miles club'' and even one with 400k miles. A 'real' fully loaded E90 can compete with ease with most modern standard cars for a fraction of the price. |
04-05-2024, 12:14 PM | #4 |
Rep 30
Drives: Bmw 328xi
You give me a hope not to sell it right now lol. Need to consider pros cons
04-05-2024, 01:05 PM | #5 | |
Rep 899
09 328i TiAg 6MT barebones with sport package
04-07-2024, 04:19 PM | #6 |
Rep 5
Be proactive instead of reactive with your maintenance and she'll be good to you. I DD a 2011 328i xDrive with 352K KM
COMING SOON: H&R Sport Springs w/Bilstein B8's, ECS F & R Suspension Refresh Kit HD - Level 3, Dinan Fixed Camber Plates, STRONGFLEX Yellow FCAB, M3 Rear Arms, H&R 20mm Rear Sway Bar, Turner Motorsport Performance Rear Sway Bar End Links, ECS Exact Fit SS Lines, 335i Front Brake Swap, ECS Front Caliper Performance Caliper Guide Bushing Set, Turner Motorsport Polyurethane Engine Mount Set 80A, ECS Performance Polyurethane Differential Bushing Set 95A, ECS Performance Polyurethane Subframe Bushing Set 95A
bimmer328xi9.00 |
04-07-2024, 05:50 PM | #7 |
Rep 30
Drives: Bmw 328xi
What an attitude to the car, good for u. What's your yearly maintenance cost??
