02-24-2020, 01:31 PM | #1 |
Rep 132
Oil Interval Coding
I tried to code a different oil change interval, yesterday, but ISTA-P fails when trying to write to the DDE (I have an X5d).
The error is: Global VehicleCommunication CoA Pt 1000 - (CoAPI) - General fault Also, ISTA-P asked for an IBAC code. I used a generator and my VIN to create one. I am confused about the key # in the generator. I verified my fob was #1 and used #1 in the generator. ISTA-P accepted the generated code and proceeded to the coding processes, but then the DDE had the com error, above. Weird. |
02-25-2020, 07:06 AM | #2 | |
Rep 119
apexit41230.50 |
02-26-2020, 06:34 AM | #3 | |
Rep 1,101
And thanks for spelling out exactly how to do it, I've been meaning to set up INPA/ISTA to do this and just couldnt find the time. Should be easy to do now! |
02-26-2020, 06:55 PM | #4 | ||
Rep 554
Drives: 2018 M5 / 2011 X5 35d
03-04-2020, 06:13 AM | #5 | |||
Rep 1,101
03-04-2020, 11:16 AM | #6 | ||||
Rep 554
03-05-2020, 02:59 PM | #7 |
Rep 1,101
Attachment 2253567Here's a screenshot of the argument field and the execute button. I tried to upload it from my phone in my earlier post but it didn't work for some reason.
03-27-2020, 09:31 PM | #9 | |
Rep 1,101
Is this normal? Are the instructions you outlined only temporary? Is there a way to make this change permanent so that the next time the interval is reset using the cluster, it resets to the value I set using ProTool? |
03-28-2020, 08:29 AM | #10 | |
Rep 119
