07-30-2018, 02:26 PM | #1 |
Rep 728
X5M Guibo Flexdisc and Center Bearing
Gents,
Anyone tackle this? I was scooting around under the car and noticed mine was shredding. I’m guessing I should replace the center bearing also? Looks like I have to take off the exhaust, plastics, and heat shielding to reach the shaft. I’m pretty sure I dont have to drop the whole shaft...and I don’t want to have to replace stuff on the diff end. I think just flex disc, center bearing, sleeve, bolts and nuts. I didn’t see a requirement for washers on the X5M on realism...was all grayed out. Thoughts? Also, I called an Indy and they said $600 to replace guibo only...eek
2020 G01 X3 30e CURRENT M Sport Package 2019 Ford Raptor SuperCrew CURRENT 802A, KN Drop-in, RB Flaps, Husky Well Liners 2012 E70 X5M SOLD Stg 1+ Turbos, DPs, Velos Stg 2+, JB4, Race Cats, Bavauto Coils 2003 E46 M3 SOLD aFe CAI, AP Axleback, SSK, H&R Springs, TMS CMBR Arms, PF RTABs |
07-30-2018, 03:27 PM | #2 |
Rep 291
Hopefully the driveshaft design is like the older BMWs where there are splines where it can slide back a little. This is usually enough to swap the fexdisc without pulling the whole driveshaft out.
You might be catching this before there's any damage to the center bearing or the rubber surrounding it. Last edited by philly42; 07-30-2018 at 11:23 PM.. |
jandref321346.00 |
07-31-2018, 08:57 PM | #3 |
Rep 728
Thanks! I'm gonna give it a go. I already have the flex disc, forgot about ordering the other stuff. Bolts, and center bearing enroute...just in case
08-11-2018, 05:29 PM | #4 |
Rep 728
I finally got around to dropping the exhaust and taking a better look at everything. The Guibo does have little cracks and some big chunks taken out. The Center bearing mount has a coating flaking off with minor cracking in the rubber underneath. I have all the parts, just have to get at it after figuring out how to throw it in neutral to be able to rotate the shaft...the red disconnect tool?
08-11-2018, 06:58 PM | #5 |
Rep 287
I'm getting a driveshaft recall done shortly... has anyone had this done and know what's involved? It doesn't include guibo / centre bearing by chance? I have a clunking sound when I go in reverse, and the car needs a good amount of throttle to start moving.
Drives: 2010 E70 X5M Carbonschwarz Loved and lost: 07 E92 M3 Silverstone II / 96 E36 M3 Evo Estoril Blue / 07 E84 Z4 M Coupe Interlagos Blue |
08-11-2018, 07:24 PM | #6 |
Rep 728
Recall is for the front drive shaft only. The M doesn’t have a flex disc on the front shaft
09-03-2018, 11:45 PM | #8 |
Rep 728
I’m at 74k miles now. I ended up swapping only the flexdisc. It is a considerable task disconnecting the driveshaft pieces and removing the center bearing. It actually calls for a special tool. When I went to separate the shaft I found that I had to break an internal plastic ring to pull it apart...after Messi g with it for some time I decided it wasn’t worth the trouble since it all looked in good shape. I’ll post about the parts with pics tomorrow.
09-04-2018, 01:30 AM | #9 |
Rep 3,154
Does anyone have the copy of the SIB for the recall? Thank you.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
Tags |
bmw, e70, flex disc, guibo, x5m |
