      06-19-2020, 01:30 PM   #1
Edwardscarpa
Drives: Bmw x5
Exclamation 2008 X5 V8 4.8i E70 Suspension
So just bought this x5 it had a couple camshaft position codes that was all, replaced 2 camshaft sensors still have that problem and dont know what i should do to clear the camshaft engine codes, Bank B intake and exhaust or something like that... BUT... My main problem is that now the back end is squatting all the way and the suspension level control system malfunction. Idk if maybe there are common fixes for this or if maybe the air pump goes out alot or typical after 12 years... I looked at each wheel area for the little connector rods hoping maybe one popped off but i couldnt see anything wrong amd my bimmer has like no suspension now.
      06-19-2020, 01:55 PM   #2
Edwardscarpa
Drives: Bmw x5
And i just pulled it into garage i definitely hear the pump woeling and a big aor loss on my rear driver side tire
      06-19-2020, 02:24 PM   #3
argento
argento's Avatar
538
Drives: 2013 X5M
Check you rear susp air bags to make sure no leaks.
https://www.realoem.com/bmw/enUS/sho...diagId=33_1389
      06-19-2020, 09:05 PM   #4
Edwardscarpa
Drives: Bmw x5
Def air bags, any how to on specific e70 x5 i vant seem to get the bottom clips pinched enough to take it out i assume thas all just get it un wedged and replace?
      06-20-2020, 12:05 AM   #5
argento
argento's Avatar
538
Drives: 2013 X5M
Start here: https://www.newtis.info/tisv2/a/en/e...s-rear/P5dYGU3
Then here:
I haven't done, but doesn't look too bad.
Good luck.
      06-21-2020, 12:00 AM   #6
Edwardscarpa
Drives: Bmw x5
Awesome! Problem solved for my suspension, shall i make a new post on my camshaft position sensor problems im running a few codes all camshaft position one is over advanced somethong and one is exhaust and intake and one more i believe but the new camshaft position sensors on both sides didnt fix it. I did the ones in the back of the engine on top one on both sides
