      08-07-2016, 03:21 AM   #1
khello
Drives: 3coupe
Bmw x5 35i MY 2011
Hello,
I am willing to buy an x5 facelifted MY 2011. It has 66000 miles on the clock. I need advice from the owners. ( fiability...). I had a 335 coupe My 2007 had too much problem with the fuel pression pump. So thats why im afraid to buy it. Here are some phtos.
      08-07-2016, 06:21 AM   #2
racermp
racermp's Avatar
Drives: F30 330i
I have a 11 not my, however i had a hpfp go out recently. Yay the warranty is only for n54, however i have rt66 so they covered it. Oh and the transfer case. Other than that, i keep hearing the n55 is alot more reliable in other terms
      08-07-2016, 10:04 AM   #3
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
My '11 3.5i has been bulletproof-no problems. I don't drive much, and have 53k on the clock.
      08-08-2016, 08:10 AM   #4
omgboost
Drives: 2012 X5 35i
Watch out for the Oil filter gasket and the lower oil pan gasket. I had those replaced because of oil leak at a hefty price... These are very common problems with the N55, not just the X5.
      08-09-2016, 10:39 AM   #5
-c-
-c-'s Avatar
Drives: bmw
Don't forget the valve cover gasket oil leak that to fails on the N55.
They recommend replacing the whole valve cover as well as it can crack.
So check around the valve cover to look for leaks.
      08-09-2016, 11:26 AM   #6
Poppyboy
2011 X5  [10.00]
My brother has this going on right now with his '13 with 55k miles. I haven't had the problem on mine, thankfully.
