      01-23-2016, 10:28 AM   #1
s65m3fan
s65m3fan's Avatar
Drives: 2013 BMW M3, 2013 X5 35d
Lumen LED Brake/Stop Light Bulb
Anyone replaced the incandescent rear brake light bulbs in the E70 LCI tail lights with LEDs? I haven't found much info. Found these this morning. Any experience or recommendations with these or others?
http://www.carid.com/2013-bmw-x5-led...-25670991.html
2013 Jerez Black E92 M3 DCT ZCP | PFC Z54/Z45 BBK | MCS 2-way Remote Dampers | Hypercoil 600/900lb Springs | Ground Control Race Camber Plates | Bimmerworld Control Arm Bearings | Powerflex Sway Bar Bushings and Shock Mounts | EDC Delete | Macht Schnell Stage 2 Intake | Akrapovic Exhaust | Bimmerworld Race Studs | CSF Radiator | CSF Oil Cooler | Bimmerworld Power Steering Reservoir | Euro MDM | Lux H8 160 | BMW CF Front Splitters | BMW CF Competition Rear Spoiler | Schroth Quick Fit Pro | HRE R43
      01-23-2016, 01:43 PM   #2
Poppyboy
1976 Triumph TR6  [10.00]
1993 Bentley Turbo R  [10.00]
2011 X5  [10.00]
I did with WeissLicht. They look pretty good. Lots of threads on here about their LED bulbs. http://www.weisslicht.com/
      01-23-2016, 08:50 PM   #3
Deftronix
Drives: 12 X5d & 20 X7 M50i
+1. Replaced the brake, turn signals and reverse bulbs with WeissLichts. Really like the look of them and the built in resistance to keep flash rate stock. No outage warnings either. I did have to disable voltage monitoring for the reverse bulbs as I would get an occasional flicker while not in reverse however.
      01-25-2016, 01:47 AM   #4
XFIVEM
Drives: X5M
I used the Weisslicht spektrum led bulbs from Bimmian on my headlights and tails. They work great and seems to be the latest bulbs they make.
Only thing is you have to code the flashing at the vehicle start up. They work great and extremely bright. Also take advantage of the low Canadian dollar!!! Heres a link below.
https://bimmian.com/Accessories-for-...-Signal-Bulbs/
