      05-31-2021, 11:08 AM   #1
geo335
Drives: BMW F30 335i
Thumbs up Which Parts will fit to F15 from E70 - tech thread-
Hello fellaz,
Let's discuss as I was not able to find related thread.
I have damaged F15 from right front side, and In my country people are asking way too much for F15 parts, I know some parts are fitting without problem, sellers trying not to say true to clients aswell.
So lets move on
What I changed successfully is :
1) Rear wishbone upper one
2) Absorb shock ( front & rear )
3) rear lower control arm (hub)
What did not fit :
1) front control arm
2) front axle
--- Also I want M steering wheel "heated"
Can I find it in F30 section? will it fit ? will rear paddles and heating work ?
--- One more I have E70 M wheels/tires will they fit without spacers?
What do I have to replace here is list so guys please tell me if I can fit some from e70 as its cheaper.
I need front intake kit
Radiator kit with front panel
cooling system water hoses some pipes
please check photo for more details
what I got is body details only for now and I need front replacements to build it up
thanks for ur time
if you can link each part I need it will be awesome as I ll be possible to do research before sellers gonna scam me )
      06-05-2021, 01:35 AM   #2
pdX5M
pdX5M's Avatar
Drives: E70 X5M
2013 BMW X5 M  [0.00]
I'm not sure on a lot of those items but I do know that if the wheels are from an E70 X5 M, you'll have one pair (front or back) that will have a different hub bore so you may need an adapter.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
