      01-28-2011, 09:32 PM   #1
Kloogy
Kloogy's Avatar
Drives: 2011 BMW X5 Sport
Those with Hardwired Radar Detectors ....
What's the easiest spot to tap for power ? I'm hardwiring my V1 and wondering what would be the easiest place to use as a power source. If you have pics please post up ! I would greatly appreciate it.
2011 X5 Sport
Black Sapphire w/ Black Perforated Nevada/ DK Bmboo
Technology/ Vented Seats/ Cold & Convenience / Multi Contour seats/ 20" wheels and more...
2004 Mustang GT Vert. - Modded
      01-30-2011, 11:23 PM   #2
Kloogy
Kloogy's Avatar
Well, I figured it out. Dropped the overhead console and tapped into a simple power source. Took all of 15 minutes. If anyone is interested in the info, let me know.
2011 X5 Sport
      01-30-2011, 11:54 PM   #3
Nick Daffern
Drives: 2022 X5MC
I've got a V1 I'd like to hard wire. What do you recommend?
      01-31-2011, 01:11 AM   #4
Kloogy
Kloogy's Avatar
There is a green wire with a white stripe that runs from left to right inside the overhead console. If you pop the console out, you will see it running close to where your windshield is. It's wrapped up with a few other wires. Loosen it from the other ones just enough so you can put the tap provided with the V1 right on it. To the left you will see a torx nut that already is a ground. Loosen it, and slap your V1 ground on to that. You're done ! Took me around 15 minutes. A member on another forum posted detailed pics. I'll see if I can put them on here so you can see.
2011 X5 Sport
      01-31-2011, 01:14 AM   #5
Kloogy
Kloogy's Avatar
Here you go
2011 X5 Sport
      01-31-2011, 04:43 AM   #6
ad78
Yr1OfD1
ad78's Avatar
Drives: 2015 F34 M Sport
How do you pop the overhead console? I have 2011 and I'm afraid to
Do it.. Do I need to start at the back? Near windshield?
      01-31-2011, 10:35 PM   #7
Kloogy
Kloogy's Avatar
Near the windshield. Just give it a good tug. Comes right off.
2011 X5 Sport
      02-02-2011, 12:42 PM   #8
lensman5
Drives: BMW X5 Platinum Gray ...
If i do this will it void the warranty?
      02-02-2011, 10:26 PM   #9
Kloogy
Kloogy's Avatar
Why would it void the warranty ? Come on people !
2011 X5 Sport
      03-08-2015, 02:21 PM   #10
JeST
Drives: X5M
Anyone have those pics saved by any chance? Thanks!
      03-08-2015, 03:53 PM   #11
JeST
Drives: X5M
Found the pics. Thanks Kloogy
      03-08-2015, 06:25 PM   #12
brian5
Shoot for the moon
brian5's Avatar
Drives: 2008 X5 4.8i
I used to have my V1 hard-wired but using the SAVVY is so much better. I'm not bothered by low speed alerts any more.
      03-08-2015, 07:44 PM   #13
muddycharles
Drives: 2011 X5 M sport
I have hardwiring for my three cars (X5 is one) - and I used the invisicord as it does not require a tap or any stripping of wires. I also special ordered one that allows for the connection of the V1 LE bluetooth module (which if you get a V1 you would be crazy not to have just for the auto mute alone)
http://www.invisicord.com/index.html
      03-09-2015, 08:35 AM   #14
MRV99
MRV99's Avatar
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
I have used this same method on every BMW I have owned. It worked beautifully on my e39,e53.e60's,e70's and e90. Worked with both escort and V1 hard wire setups. The green is a switched power which on these power hungry, low charging electrical system is perfect.
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
