08-15-2010, 09:27 AM | #1 |
Rep 1
X6 Engine Problems
I have a 2008 X6 with the twin turbo six. The car has approx. 27K miles. The engine mafunction light has come on numerous times resulting in 4 rides in the cab of a tow truck. They have replaced the injectors but I am not really sure what else they have done as they haven't been completly candid regarding the source of the continuing problem. I am ready to dump this car and ask BMW for financial re-imbursemet, under California's Lemon Law. Having been stranded four times, I don't wish to have the experience again.
Can anyone suggest a solution or give me some insight as to the source of these engine problems. |
08-15-2010, 09:32 AM | #2 | |
Ninja
390
Rep 4,014
more info regarding hpfp problems can also be found on e90posts, as early 335's also have the N54 engine. you can post in the e90posts regional section of FI section for a lawyer suggestion...
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
08-15-2010, 08:38 PM | #4 |
Rep 176
For what it's worth.....I'd make a small wager your problem may be due to your gasoline. Had the problem myself on about 8 occasions. All I did was pull over, shut it down, wait about 30 seconds and restart. Problem cleared its self. I run Shell 93 Octane and it keeps the problem away. Too much ethanol in the gas, over 10%, I'm told, does not allow the turbo chargers to run hot enough, thus the problem.
08-15-2010, 10:45 PM | #5 | |
Ninja
390
Rep 4,014
I do hope it's that simple tho for you OP..and it's not your HPFP...but I've read a few posts of early X6 models with the N54 engine also having hpfp failures...and your syptoms are similar...
08-19-2010, 01:24 AM | #7 | |
Rep 683
Ask for PUMA report
08-19-2010, 07:04 PM | #8 | |
Rep 1,209
Ask for a courtesy buy back. This is nuts. BMW will give most of your money back and put you in a new car way below cost. Why would you put up with this kind of issue for so long?
2011 535i
2008 VW GTI |
08-19-2010, 10:41 PM | #9 | |
Ninja
390
Rep 4,014
08-21-2010, 10:39 PM | #10 |
Rep 2
For what its worth I had the same issue with a 2010 X6 5.0i with the 7RR engine upgrade. At around 300 miles I started getting error messages. Took the car in numerous times and they told me it was ethanol. The 3rd time it happened (after putting in only Shell V-Power) they finally did the PUMA route and replaced all the fuel-injectors. That seemed to take care of the problem completely in my case.
08-21-2010, 11:48 PM | #11 | |
Ninja
390
Rep 4,014
