06-03-2013, 10:26 PM | #1 |
Rep 55
Possible to watch DVD on front screen?
Hi guys I have a rear entertainment system in my 2009 x6. I was wondering if it was possible to get the picture feed to the front Idrive screen? It's a CCC system I believe with a disk in the navigation dvd drive.
Is there something I can do to watch videos in the front? |
06-04-2013, 07:57 AM | #2 |
Rep 1,246
If you insert a DVD into the front CD/DVD slot, or into the 6 disk changer in the glove box, you should be able to watch it on the iDrive screen as long as the car is in park.
Once you put the car into drive or reverse, the DVD image will go away, but you csn always have your car coded in order to override that safety feature.
Too smart for my own good...
06-04-2013, 02:27 PM | #3 |
Rep 55
nope nothing happens. I take out my navigation disk and put in a DVD nothing happens. I don't have the HD I think it's a CIC I may have? And when I put a dvd in my rear entertainment and select it from the Idrive there's no picture.
06-04-2013, 11:36 PM | #4 |
*Bimmerpost Plasti Dip Guru*
81
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
Get it coded by someone in the forum that knows how to do it.
06-05-2013, 08:05 PM | #5 | |
Rep 1,246
If you haven't tried those options, give it a shot. Do NOT try the port that says DVD. That is for the navigation disk. Use the slot above that one. Hope this helps.
06-06-2013, 05:22 PM | #6 | |
Rep 55
I think i have CIC and not a CCC whichever one that isn't the HD one. I tried. If i can even get a feed from the rear entertainment to the Idrive system i'd be happy for maybe if i run an ipod that would work? |
