05-21-2020, 11:26 AM | #1 |
Rep 166
Turbo removal X5 50i
Shitty N63 engine.......Does anyone know how to remove the turbos specifically the Y-clamp nuts at the bottom of the mid section of the turbos?
I cannot get a socket, wrench or anything to loosen the y-clamps. And how to remove the down pipes? Replacing the turbo return lines and fixing the coolant leak. Thanks, Frustrated BMW owner with time on his hand.... Last edited by Movado750; 05-21-2020 at 11:30 AM.. Reason: Title |
05-21-2020, 11:54 AM | #2 | |
2022 M4 Comp Xdrive
1016
Rep 1,538
The downpipe process is pretty straightforward. U gotta unbolt the two nuts on each side underneath where the downpipe meet the front pipe. Then the heat shield bolts e8. Then from top once u get the heat shield off you have the v-clamp that keeps the downpipe attached to the turbo. They come off and the Downpipes should wiggle out |
05-21-2020, 05:07 PM | #3 | |
Rep 1,564
You dont have to remove the downpipes to pull the turbos but you need to remove them for another reason its a challenge, there are some hidden bolts on the back of the engine you have remove that suck to get to on the drivers side due to the transmission cooler lines |
05-22-2020, 08:59 AM | #4 |
Rep 166
Yes that’s the bolts I talking about...Man , that’s what I thought would be the answer. Holy cow I’m this far might as well go all the way I guess.
Damn Germans..... |
