F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Strange humming noise from 100kmh till 130kmh
GetBMWParts
      01-19-2023, 01:30 PM   #1
Robertjuhh
Drives: 320i F31 lci
Hello all,
I am from the netherlands, so my english is not perfect. I have a problem with my F31. Until 100kmh its perfect, no noise. From 100kmh till 130kmh, i have some humming or pulsating noise. Noise sounds deep, you feel it in your ears but its absolut not a loud noise. My wife does not hear it but i am freaking about it. My garage has mounted a new differential but the noise is still the same. Now i am a few weeks further and i think the sound is coming from the front. I think wheel bearings. Is this possible or does anyone another idea?
      01-19-2023, 03:48 PM   #2
Sammy17
Drives: 440ix, x3m
Originally Posted by Robertjuhh View Post
Hello all,
Could be wheel bearings either front or rear. Front is very easy to change you can do it yourself, rear takes much longer around 4-5 hours.
      01-19-2023, 03:53 PM   #3
zrile
zrile's Avatar
Croatia
91
Drives: BMW F31 320xd
I had similar situation, from 140 to 160 kmh! Any revs,any gear, same sound... mechanics said differential, or xdrive unit, or chain.....problem was in empty a/c system! After 20 dayswith that sound and expensive diagnosis "this or that", a/c stopped cooling. I got to refill a/c gas, go along my way and noise was gone! Try with that first! Cheapest fix!
      02-08-2023, 03:09 PM   #4
Robertjuhh
Next week, the garage will mount 2 new wheelbearings in the front. I hope this will fix the problem.
      02-08-2023, 05:10 PM   #5
im_an_alien
im_an_alien's Avatar
1151
Drives: 2016 340i
Hope that fixes it, keep us updated. Some people have reported a humming sound at around 60 mph/100 kph that was resolved by a driveshaft replacement.
      02-08-2023, 07:25 PM   #6
Wires
Drives: 2016 340i xDrive
Mine had that when new. One front wheel bearing was bad.
      02-09-2023, 09:16 PM   #7
90rr
90rr's Avatar
Drives: 2021 M340i
This was my problem: https://youtube.com/shorts/joYI_RgRVpU?feature=share
No grinding noise or wheel play. My rear bearing turned out to be faulty, and the wheel itself was slightly bent.
      02-10-2023, 02:13 PM   #8
Robertjuhh
14-2 the garage will mount both wheelbearings in the front. I will keep you updated.
Wires1657.50
      02-12-2023, 07:52 PM   #9
agentorange
Drives: 328d
Vibrating underbody panels can also cause this type of noise.
      02-12-2023, 10:59 PM   #10
JBH6612
Drives: 2017 430i coupe M package 6 sp
2017 BMW 430i  [0.00]
Following. Please post update as I’m having similar humming issue. Getting new tires tomorrow which is another expensive experiment.
      02-13-2023, 04:20 AM   #11
Robertjuhh
Hi agentorange,
Underbodyparts are fixed by the garage. There is a PUMA with this problem form BMW AG. They said, they solved it in my car. BMW dealers know about the body parts. Tommorow they will mount 2 new wheel bearings. I will keep you updated.
      02-13-2023, 07:55 PM   #12
JBH6612
New tires reduced the noise just a bit. I was originally running two summers in the front and two all seasons in the rear, different brands don’t ask why that’s how previous owner set them up. Tire shop said i got two bent rims in the rear so getting them fixed tomorrow.
      02-13-2023, 11:20 PM   #13
samx3
Drives: bmw
How often do you do balance and alignment and rotation for your car?
Check your tires if they look like this?
Bold from the inside
      02-14-2023, 02:52 PM   #14
JBH6612
Sorry to hijack this thread. The same humming noise is driving me crazy and since misery loves company, I’m venting in this thread. Wheel repair shop found 3 bent rims so they’re fixing them.
So far, I’ve gotten new tires balanced, rims repaired. I’m out about $1000 right now and if this doesn’t fix it, then I’ll suspect wheel bearings.
      02-15-2023, 01:31 PM   #15
Robertjuhh
So my wheel bearings are changed yesterday but the humming noise is still the same.
Does anyone know what this can be? I am still thinking about body parts or maybe the shock absorber?
      02-15-2023, 01:33 PM   #16
im_an_alien
1151
Drives: 2016 340i
Driveshaft is the likely culprit...
      02-15-2023, 01:42 PM   #17
Robertjuhh
My wheels and tyres are new. Original wheels and Michelin tyres. I tried also another wheelset, and this gives the same noise. The noise is also not every day the same. Sometimes the sound is almos gone and sometimes the sound is really frustrating me.
Hope someone gives the right answer.
      02-15-2023, 02:23 PM   #18
Robertjuhh
Hi im_an_alien,
Yes maybe possible but the sound/noise is not always the same. Sometimes its much louder than the other time. Can this still be the problem?
      02-15-2023, 03:00 PM   #19
JBH6612
Did the repair shop say only two front wheel bearings were bad? What about the rear ones?
      02-16-2023, 03:09 AM   #20
Robertjuhh
Hi JBH6612,
The garage said that the ones in the rear are good.
      02-16-2023, 03:10 AM   #21
Robertjuhh
The noise / sound is also coming from the front. I dont hear it rear....
      07-31-2023, 05:53 PM   #22
bigshooter
bigshooter's Avatar
Drives: 2014 328d xDrive
You mentioned it was your rear wheel bearings making that noise. Were you hearing the noise from the front?
f30post
