07-01-2012, 03:42 AM | #2 |
Rep 213
You put 11k down on a lease? If so then it is a horrible deal. You will never see that money again. Unless I read this wrong and you did MSDs???
2014 Range Rover HSE- Fuji White/Ebony
2014 MB E550 Sport Sedan Sold: 2011 328xi; 2013 X3 35i; 2013 X5 50i |
07-01-2012, 12:42 PM | #4 |
Rep 213
Even if you are going to buy it, why let the bank hold your money for 3 years? Further, why not just put the 11k down and finance the car. Sounds like your situation calls for a purchase not a lease.
Multiple Security Deposits are used to buy down the money factor each by .00007 up to a total of 7 (with BMWFS). That will lower your payment and at the end of the lease you get the deposits back. In many cases, people actually are making money this way. *disclaimer- I am not giving you financial advice. In my opinion, money down on a lease is a loser no matter what your intentions are with the only exception being MSDs.
07-01-2012, 01:20 PM | #5 |
Rep 910
Did you run the numbers based on doing a 5 year financing term. Since you are planning to buy at the end of the lease anyway it probably makes more sense to finance. I'm seeing rates as low as 1.9%.
07-01-2012, 08:00 PM | #8 | |
Rep 213
Good luck.
07-01-2012, 10:12 PM | #9 | |
Rep 878
07-02-2012, 11:44 AM | #10 |
Rep 70
Instead of using $11K as a down payment - ask them to recalculate it using it as multiple security deposits. This should lower your rate, and you will get the money back at the end.
Lease vs. purchase - the special APR is 2.9%, I don't know where people get 1.9%, it is not currently available. Plus you will plunk down sales tax on the whole car, instead of just the lease payment. |
07-02-2012, 11:45 AM | #11 |
Rep 70
07-02-2012, 12:24 PM | #12 |
Rep 1,037
if you're planning on buying, you should buy it now - o/w you will lose more in the long-run. that is the only way to justify plunking 11k down into a depreciating asset. At least, if you're buying the depreciation dramatically reduces after 3 years. If you're leasing, you just chunked cash into the worst part of the depreciation cure.
don't take this the wrong way, but 11k down on a lease is the stupidest thing I've ever heard off.
2014 335i RWD: ZMM, ZDA, ZDH, ZPP, ZTP, 2NH, 2TB, 5DL; Z4A MPPK; AW ext / VB int
07-02-2012, 02:09 PM | #14 |
Rep 122
Just use the $11K for a year's worth of payments. Set-up a new checking/mm account, and do automatic withdraws to BMW. If you continue to deposit $550 a month - as you plan to pay with the down payment - you will have another set 6 months payed out by the end of the year.
07-02-2012, 08:13 PM | #15 | |
Rep 213
You asked if you got a good deal. You didn't. You are either not understanding the logic or buying more car then you can afford. If you want a lower payment, drive a less expensive car. You can't change the fact that the numbers are the numbers. I'd suggest buying a less expensive car, which gives you lower payments and discretionary moneys. It also makes fiscal sense. Sorry for the bad news but I think you wanted someone to tell you not to do this. Hence your thread...
07-02-2012, 08:16 PM | #16 | |
Rep 213
07-04-2012, 09:03 PM | #18 |
Rep 161
i am sure you have done your shopping before you purchased. you know what is the best price for the truck you get with the options you wanted. as you said you ran the numbers and it will be about the same. i am saying prices vary depend on many factors, like from regions to regions, dealers to dealers, etc. it seemed like you don't trust your decision, and have some doubts about the deal you signed. a good deal is the one you comfortable and can live with, regardless of everyone's opinion. I was just wondering why you have to bring it here, and why you have to check with your coworkers, and double check with sales person, salesperson is never on your side.
07-04-2012, 10:11 PM | #19 |
Rep 910
I just ran the numbers and it looks like your lease will end up costing you about 6k more over a 5 year 2% finance with 11k down.
Go with the financing and save yourself 6k! To run the number yourself simply calculate your total spend after you lease for 3 and add that to the residual which will be your buy out at lease end. The best deal for you is to finance and with that credit score you should be able to get sub 2%. Good luck! |
07-05-2012, 12:40 AM | #20 |
Rep 271
if you're going to buy it then why lease it? that only makes sense when the lease finance rate is lower than the loan finance rate (like Nissan/Infiniti is right now). BMW lease rates work out to over a 4% APR. Even maxing out the MSD's, it's cheaper in the long run to get a loan at 1.9%.....
07-05-2012, 03:53 AM | #21 | |
Rep 213
Lease will cost you $20 plus the buyout will cost you $38, plus the $11 you put down. That's $69K. What B-school did you go to? You are effectively paying full MSRP plus the warranty. That's a bad deal. Not to mention you lose the use of the money for 3 years. If you can't tell, not one person in this thread told you this was a good idea. By the way...What does an 826 credit score have to do with what you can afford? Again, at 1.99% for 60 months you should finance this vehicle.
07-05-2012, 06:42 AM | #22 | |
Rep 5,733
Drives: '24 iX50; '23 i4 M50
For a one time $20 membership fee, nothing beats PenFed's 1.99% if you have to finance
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
