07-18-2020, 11:50 PM | #1 |
2022 M4 Comp Xdrive
1016
Rep 1,537
F85 rotors on e70 x5m
Anyone who has does this swap, any noticable braking differences?
Looking for a justification on the cost other than looks. I'm perfectly fine with the stock blank rotors for the e70. |
07-19-2020, 10:20 AM | #2 |
Rep 357
Drives: E70 X5M
I've seen it done on this forum. I think the posts were from a ways back but the F85 rotors just bolt right up - minus one set screw. If I recall correctly the E70 rotors use two set screws and the F85 only use one so you'll have a leftover bolt.
As for improved performance I doubt you'd notice any. You would probably need to upgrade the calipers to 6 pot front and 4 pot rear to really notice any difference in braking performance. The improved looks are ALMOST worth the cost imo.
- 2013 X5 M - Silverstone Metallic w/ Black Perforated Complete Merino - All OEM Options - 12.5mm/20mm Spacers - Velos Stage 2 - xHP Stage 3 - AA Catless - Megan Racing Supremo - PTP Blanket - K&N Drop In -
07-19-2020, 11:59 AM | #3 | |
2022 M4 Comp Xdrive
1016
Rep 1,537
Eh, it's twice the cost just for looks. I'll pass on em then. |
07-19-2020, 04:10 PM | #4 |
Rep 69
I'm going for the retrofit where I'm installing the 6 pot F10 M5 brake calipers on the front and 4 pot panamera calipers in the rear.
Initially I was going to also go for the drilled rotors but after taking a look at the price, I'm sticking with the non-drilled and don't think it'll make much of a difference aside from looks. A beefy 395 in the front, and 385 in the rear doesn't look all that bad either. |
07-19-2020, 06:16 PM | #5 | |
2022 M4 Comp Xdrive
1016
Rep 1,537
Do those calipers need a different bracket or do those bolt right up? |
07-20-2020, 02:50 AM | #6 | ||
Rep 69
07-20-2020, 03:49 PM | #7 | |
2022 M4 Comp Xdrive
1016
Rep 1,537
It's like the hand of Thanos grabbing the rotor. Now that's some stoppage. 😂 |
07-20-2020, 07:06 PM | #8 | |
Rep 994
In a single panic stop, assuming both have the same tires. The non-X5M will stop just the same as the X5M. Repeat that exercise multiple times, back to back, and you'll see where the extra rotor mass comes into play though... Of course, there is no discounting the feel of freshly flushed brakes, and a fixed caliper over year old fluid and a sliding caliper too. In many cases, more pistons in a caliper, may mean smaller pistons, and sometimes in properly designed braking systems, move bias rearwards. So your larger multi-piston brake system, actually clamps LESS than, the factory system. Crazy right?! Science, it's cool stuff |
07-21-2020, 12:34 AM | #9 | |
2022 M4 Comp Xdrive
1016
Rep 1,537
No idea where you're getting these assumptions from 😂 Where is the non x5m in the conversation above? I'm using the stock x5m caliper on my x5m. I said it works just fine so I don't see how going to the 6 pot is going to be much more different and worth the change. |
08-31-2020, 11:15 AM | #11 |
Rep 299
I use these rotors on my E70. https://www.r1concepts.com/detail_ca...otor+silver+++
Keep and eye out for their frequent sales of up to 20-30% off. Along with EBC red stuff pads, the stopping is improved and they look great. That being said, there is nothing wrong with OEM stopping performance, this just takes it up a notch. EDIT: Just got an email with a 30% off coupon MOREPOWER for today only, which brings down the price of a complete set of 4 rotors (slotted and drilled) for $243.38 +tax. (free shipping) Here is what they look like on my X5. (Sorry not the best pics, but hopefully you get an idea) Last edited by hilld; 08-31-2020 at 08:17 PM.. |
08-31-2020, 12:21 PM | #12 | |
Rep 491
I used https://www.brakenetic.com/product/f...ors-bprs94699/ Slotted rotors and EBC Red stuff pads for my X5 V8 and its stops from 80mph like it hit a wall Quote:
08-31-2020, 12:30 PM | #13 | |
Rep 674
My front rotors are F10 M5 which are slightly larger and noticeably lighter than the F85s but front calipers and rear rotors are F85. https://www.xbimmers.com/forums/show....php?t=1715639
N54 Powered M5 Wagon:
- M5 Shaft, M5 LSD, M5 Axles, M5 Brakes, M5 Front End, M5 skirts, M5 Mirrors - Manual Swap, MFactory SMFW, Spec Stg 3+, KW V3, RD Sport Sways, F14 SDC - EOS Port Injection Manifold, Fuel-It: Stg 2 LPFP +Lines +Ethanol Sensor - JB4, Hexon RR550s, Custom Inlet, AR DPs, 3" Exhaust, VRSF 7" IC, ER CP +Tial Last edited by ucsbwsr; 08-31-2020 at 12:36 PM.. |
m5james431.00 |
08-31-2020, 09:43 PM | #14 |
Rep 755
Drives: 2019 BMW X6M
X5M OEM brakes are more than good enough IMO, even for my stage 1 tune. On the looks department, painting my calipers in Blue on my Carbon Black Metallic X5M made me more than happy.
2019 BMW X6M
2013 Lexus RX450H 2010 Nissan GTR AMS Omega 14 |
09-01-2020, 12:50 PM | #15 |
Rep 1,716
I'd like to add this to the OEM+ list for my 35d. After researching numerous threads, I was hoping someone could just verify the following as no one has really given a part number breakdown of all parts needed.
Parts Needed: E70 X5M Front Calipers (L) - 34116789341 E70 X5M Front Calipers (R) - 34116789342 E70 X5M Rear Calipers (L) - 34216789349 E70 X5M Rear Calipers (R) - 34216789350 E70 X5M Rear Carriers (2) - 34216789351 SS Brake Lines - 002565ECS01AKT2 F85 Front Rotor Set Screws (2) - 34111123072 F85 Rear Dust Shields (2) - 34216857982 F85 Front Rotors - 34112284901KT F85 Rear Rotors - 34212284904KT OEM Brake Fluid - 81220142155 (or any alternative) E70 X5M Rear Carriers - 34216789351 or is it 34217847226? to clear the F85 rotors?
2016 F31 328iX | Alpine White | Black | ///MSport | iND | Eventuri | AC Schnitzer | MPerformance | 513M | Michelin PS4 |
2005 | 330CiC | Sparkling Graphite | Black | 6MT | ZHP Purchase your W///AGON Stickers Here: https://f30.bimmerpost.com/forums/sh....php?t=1930190 |
09-01-2020, 06:57 PM | #16 |
Rep 755
2019 BMW X6M
09-01-2020, 07:58 PM | #17 | |
Rep 2,062
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's '97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's |
09-02-2020, 11:00 PM | #19 | |
Rep 73
05-28-2023, 09:08 PM | #20 |
Rep 521
05-28-2023, 11:38 PM | #21 |
Rep 28
05-29-2023, 09:00 AM | #22 |
Rep 872
Same here. Plan to do the fronts this summer.
2013 X5M AW/Blk
Build Thread: https://www.xbimmers.com/forums/show....php?t=1499820 |
