      04-01-2021, 08:41 AM   #1
Autobacs
Autobacs's Avatar
Drives: 2019 BMW X6M
CEL for coolant pump fault
SO, I have the X5M in an independent shop for the first time ever since buying it a little over 2 years ago and approximately 15K miles of driving fun. The rear air suspension bags are leaking/frayed, going to have my transfer case oil replaced, coolant expansion tank leaking (again after replacing one year or so ago using Hella brand). I was also told my battery was NOT registered when replaced 3 years ago at BMW San Diego and my turbo coolant pump is showing a fault.
Questions: How do you determine if the battery is registered or not. It seems like a nil chance to me that BMW San Diego did not register the battery when they installed it and the maintenance records state they were replaced and registered. Second, I had no CEL's whatsoever when I brought in the vehicle initially, specifically for the coolant leak and rear suspension. Would not the faulty turbo coolant pump trigger a CEL?
Using my Red Shield exclusionary warranty for the first time. They are sending an adjuster and let's see how it goes.
2019 BMW X6M
2013 Lexus RX450H
2010 Nissan GTR AMS Omega 14
      04-01-2021, 09:28 AM   #2
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Most BMW specific codes won't trigger a CEL unless it also violates standard OBII emissions codes. The only way to even know you have a BMW code thrown is to have scanner that can read BMW codes like the foxwell nt510 or ISTA on a laptop. Either will also give you details on last battery registration.
There is an open recall on the turbo water pumps for all n63/s63's. Jump on the bmw recall webpage and type in your vin and see if yours is included.
      04-01-2021, 09:53 AM   #3
Autobacs
Autobacs's Avatar
The "electronic auxiliary water pump" was replaced on the recall almost 3 years/18K miles ago. Zero open recalls, they all have been done, i.e. injectors, driveshaft, airbags etc.
They say it is the turbo coolant pump that is faulty, which I see listed as a separate part from the auxiliary water pump at the FCP Euro website.
I already ordered a scanner, which cost less than the charge for a registration.
2019 BMW X6M
2013 Lexus RX450H
