01-19-2018, 12:10 PM | #1 |
Rep 638
Building a race car - help
So I've nearly finished building a race car.
I've also built a trailer to pull it in, it's in fluoro pink, with rear engine. Started it about 2 weeks ago ....................... ITS A TOY !!! hahaha, My daughter's church has a race tournament every year, they provide a wood template and you whittle, spray etc. Then they put it on a track, and you race against other kids So this year I took charge.. my daughter is like, "when can I do something Dad" !!!! hahaha So I have a question , regarding the wheels. So the body is wood, the wheels are a crappy hard molded plastic, no rubber tires as such, secured by pins to a cut out in the wood. I CAN'T modify the wheels, can't add bearings, springs etc. Also I'm limited to a weight, Now, I am allowed to "lubricate" the wheels and wondering what best to use. Any thoughts, some silicon spray on the pins , a small drop of engine oil Would scratching/roughing up the wheels give better speed. Basically it's a downhill slope, both cars are against a gate, lift gate and the cars roll I'll get some pics when I get home |
01-19-2018, 12:58 PM | #3 |
Rep 638
oh checked this out....... nice
gonna try and get the weights on, and some graphite greese WE GONNA CRUSH THEM LOL "but daddy it's only a car race" |
01-19-2018, 01:10 PM | #4 |
Bergspyder
1464
Rep 1,209
Tripod it....one axle a little high.
Leaves 3 wheels on the ground and less rolling resistance. Chuck the axles in a drill and polish the crap out of them Lots of weight as far back as you can get it. Higher up = more potential energy. Have fun...that is the most important part.
BimmerAg425.00 |
01-19-2018, 01:52 PM | #5 |
I'll get back to you
7556
Rep 2,132
I won the pine wood derby when i was a cub scout, my dad put weights on it. I don't *think* it was illegal.
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
01-19-2018, 02:57 PM | #6 | |
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
J/K, I don't know if he actually said it but I'm sure some F1 engineer has said that or similar.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
01-19-2018, 02:58 PM | #7 | |
Rep 11,637
01-19-2018, 06:10 PM | #9 |
Rep 11,637
01-20-2018, 08:36 PM | #10 |
Rep 1,268
I have built more Derby cars than you can imagine, built them as kid, and then again for my son while he was scouts.
The big issue is the axle and keeping the nail in the slots, so I usually make my own axles and drill a hole to put the nail into. I also sand the nails using drill to remove the burrs and make them smooth. I would press in the nails into the holes and make sure to put lots of graphite lube, there is also white lithium lube which is powder, since you're not usually allowed to use oil based lubes. Before putting the nail into the axle I usually lube the nail and put the nail in drill and put the wheel on and work the lube into the plastic of the wheel, be careful not to over heat the wheel plastic. Besides making sure the wheels are all on straight, make sure you have lube between the wheel and wood axle since this is other area o frictions. Last you need to make sure the car weighs 5 oz. I use to go to the post office and get them to weigh it for me. I also set up the car so I can add or remove weigh at race day since their scales could weight more or less. Here is where I bought all my derby car supplies http://www.maximum-velocity.com/ We won most of our races. |
01-21-2018, 11:38 AM | #11 |
Rep 638
Hey Guy's
so gonna post a few pics, as today is weighing day and I left it late so here's the scoop 1> put weights on the back near the axel 2> graphite spray lube on the axles and wheels Thats' all I really had time to do |
01-21-2018, 02:17 PM | #12 |
Rep 27
My kid's not in scouts so I don't do this now, but as a kid, I did. Got best of show a couple of times and won a couple of times as well, with dad's help, of course.
I guess one of the coolest "tricks" my dad engineered was... hollowing out part of the block, melting lead and filling the hollowed out section with it. We then went to the meet "overweight". We took a drill with us. He would get it weighed, drill a little out, repeat until we *just* met the minimum weight. |
jaye9441007.00 |
01-21-2018, 10:21 PM | #13 | |
Rep 1,268
01-23-2018, 07:59 AM | #14 | |
Rep 638
Good idea...
This place (not sure if I mentioned) is a Sunday school club. There procedure, is the completed cars are brought in and weighed, if there's a problem you get the car back, if not, they keep the car till the race. (a month or so now) THAT I don't like. Not sure WHY they do that.. After reading all the comments, sucks balls. Also on race day, the cars are taken out by the guy's doing the race, load them up and run them, parents and kids I guess are there but don't get a hand in... ALL very weird. There is a "mechanic" or looks/ tweeks/fixes the cars, but from my research, I would rather do it my self. When we do the race I'll video it and show you. Quote:
01-23-2018, 10:55 AM | #16 | |
Rep 912
Book for reference: https://www.amazon.ca/gp/product/099...?ie=UTF8&psc=1 I believe this was used in the Corvette GT1 car application. So yea, that was a good choice! |
01-23-2018, 11:03 AM | #17 | |
Rep 1,268
We have the same inspection and weigh in procedure and once the car is checked in, no one but the race official can touch the cars. Cars are always in plain site of everyone at all time, reason being no hanky panky business going on with any car. If this guy took the cars who is to say he did not drop one or knock a wheel out of whack. I personally would not be happy. I use to run the races for my sons scout pack, and it can get pretty crazy when something does no go right. You never want to be the person handling a car and drop it. We even tried to have the scout be the one who retrieve the car from the staging area and put them on the track that way if the kid drop it or did not put them on the track correctly the parents had no one but their kids to blame. Even that did not make people happy. Nice video you did for your daughter. |
jaye9441007.00 |
01-23-2018, 12:42 PM | #18 |
Rep 11,829
Drives: MY24 G01 AW Msport
cool video until i saw........................ //M on rear
01-24-2018, 04:10 PM | #20 | |
Rep 638
Yeah I agree with everything you just said
That's the word I was looking for Race Official's. Only handle the car and place on the track But yes this was all new to me and didn't make sense. When the race is on I'll go and check it out. As now I know what to look for. previously it was just a painted hunk of wood. now well now........ it's something different And If anyone;s messed with my car then there will be hell to pay. Quote:
