      08-27-2020, 09:26 AM   #1
friendlystart
Drives: X5i M-sport,E24 M635i,E34 535i
2012 50i Repeated Cylinder 2 Misfire
I have been repeatedly having the cylinder 2 misfire and recently replaced ignition coils and plugs. Also since I have 117,000 miles on my 2012 50i I replaced all four Vanos solenoid valves and both O2 sensors before the Cat because of rough startup idle and fault codes. However I still get the fault engine code for cylinder 2 misfire. Even cleaned the MAF sensors. Any ideas to what may be causing the repeated cylinder 2 misfire would be greatly appreciated!
Thanks
      08-27-2020, 07:10 PM   #2
Sophisticated Redneck
Drives: 2012 BMW X5 50i
Most likely your injector, replace them all if you have the $$$ as the rest are sure to follow. Either way order the index 12 injectors. FCPEuro has excellent prices on them
