05-19-2023, 01:07 PM | #2 |
Rep 959
ccv tubes broken
Pcv tubes broken Clogged oil return lines Oil return line block failed gasket Coolant line y connector broken Vacuum pump leaking Leaking airbags on rear suspension Leaking oil pan gasket (upper and lower) Leaking oil cooler lines (not sure if this is common, but I think mine are leaking now)
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10 |
