11-08-2022, 04:50 PM | #1 |
Rep 1
X5 E70 4 WD X5 3.0d- intake manifold is damaged
I got this car second-hand and had been driving it for a year, and the only issue that showed up on display was the particle filter [too expensive to replace, so I left it be], and recently a side light that needed a replacement warning came up.
And well, i bite the bullet and sent my beloved car to the BMW service they repaired the following. Electrical Need to check KAFAS cameras and boot camera wiring and camera for 2 hours. Engine Need to do oil service before particular filter regeneration Transmission Need to do a transfer case oil change and recalibrate. Steering & Suspension - Front Need to initialize the steering angle sensor. Engine Need to replace 6X glow plugs (could brake while removing), Glow plug control unit, Main thermostat for cooling with o ring, thermostat for EGR cooler with o ring 3Xcoolant, then need to regenerate the Particular filter. Lights Need to replace LH daytime driving light globe and holder and recheck Engine Oil Need to top up 1l of the engine oil Engine The throttle valve is jammed and needs to clean and rechecked. Today I got another surprise charge. Engine FACTORY BACK ORDER (ETA is 30/12/22 in Germany, so ETA for us would be next year.) Removed intake manifold and checked oil leak. The intake manifold is damaged. Need to replace. Due to the damage present- the Vehicle is not able to be driven. At this point in time, I just want to know if I can leave the intake manifold as it is as I am trading the car within the next 6 mths. |
11-13-2022, 01:49 PM | #2 | |
Rep 828
