10-30-2022, 03:39 PM | #1 |
Rep 58
Drives: X5i M-sport,E24 M635i,E34 535i
2012 X5 50i Fuel Injector Question
I been having a misfire on cylinder 5 so I am replacing the fuel injectors after no luck with coils and plugs replacement. I previouly replaced cyclinders 1-4 which had index 11 to index 12 because of misfires. So while removing parts to get to bank 2, I notice that the injectors are p/n 13537585261-12 which indicates a later version of index 12. However the latest version of injectors are p/n 13538616079-12.
Should I just replace cylinder 5 with the latest version p/n 13538616079-12? Need to know because injectors are now over $500.00 each. Thanks you very much! |
11-15-2022, 06:28 AM | #2 | |
Rep 178
11-22-2022, 10:24 AM | #4 |
Rep 60
I just took a look at the injectors I bought from FCPEuro about a month ago. The label on the box has the -079 part number, but the injector in side has the -261 number printed on it. So, it seems that it's the same part.
