11-09-2016, 01:52 AM | #1 |
Rep 225
Trailer brake wireless harness
Has anyone seen this? You plug the trailer brake into your cigarette lighter. I wonder if OEM coding is still required.
http://www.etrailer.com/bc-2013_BMW_...+factory+7-Way
They've done studies, you know. Sixty percent of the time, it works every time. ~ Brian Fantana
11-09-2016, 09:38 AM | #2 |
Rep 360
Well that controller will make the trailer brakes work but I'm not sure if it will make the brake lights light up.
There are others on this forum who have used it. FWIW it wasn't that big a deal to have the dealer code it for me. |
11-15-2016, 08:30 PM | #3 | |
Rep 136
Drives: X5 35d X
11-16-2016, 09:38 PM | #4 |
Rep 79
I use one too. It works pretty well but it's a pain to pair because the voltage monitor interferes with the pairing process. Despite several methods Tekonsha suggested, I ended up using a friend's Tundra to get the pairing complete. Once you go through the pairing process, the actual proportional control isn't done by the handheld module - it's in the box you mount on the trailer, so in the event you lose the wireless connection for some reason, the brakes still work.
I have an Invisihitch (highly recommend) with the BMW harness installed, then coded the hitch zoom and trailer stability control once the hitch was installed.
2013 Jerez Black E92 M3 DCT ZCP | PFC Z54/Z45 BBK | MCS 2-way Remote Dampers | Hypercoil 600/900lb Springs | Ground Control Race Camber Plates | Bimmerworld Control Arm Bearings | Powerflex Sway Bar Bushings and Shock Mounts | EDC Delete | Macht Schnell Stage 2 Intake | Akrapovic Exhaust | Bimmerworld Race Studs | CSF Radiator | CSF Oil Cooler | Bimmerworld Power Steering Reservoir | Euro MDM | Lux H8 160 | BMW CF Front Splitters | BMW CF Competition Rear Spoiler | Schroth Quick Fit Pro | HRE R43
