09-05-2011, 08:41 PM | #1 |
Rep 21
264 Wheels 255 Rear & 225 Front.
Hello - I am in the process of looking to change the tires on our 135i. I like the 264 wheel style. Can I put 255/35 R18 on the rear and 225/40 R18 on the front without any rubbing? I am talking no rubbing with full load going through mountain roads at aggressive speeds. Not really looking for any conditions. Want to make the stance contain more width with no issues. I have read a majority of the thread with no conclusive answer. A link will be appreciated if you have a link.
09-05-2011, 09:26 PM | #2 |
Rep 232
I am running this set-up with MPSS, and I do not have any rubbing issues. I did want test for rubbing when I first had them on. I drove over a raised hill that was in place for RR tracks. The suspension unloaded cresting the hill, then compressed quite a bit on hte backside of the hill. No rubbing what so ever.
I also took it out on a canyon road, and had no issues in any of the corners. I cant say I was aggressive on the road, due to being a public roadway. My car is set up totally stock with the 264 rims running 225/255.
13 Subaru BRZ, WR Blue, 6M
09 BMW135i, Alpine White, Sport, 6M - sold 99 BMW M roadster, Estoril Blue - sold |
qcodec13.00 |
09-05-2011, 11:48 PM | #4 | |
Rep 508
I have the 225/40 255/35 264 wheel setup as well on Yoko S-Drives. I have zero rubbing at stock ride hight. No roll. I had 3 passengers*+ some luggage and my sub box in the back and I still have not rubbed. This is the staggered setup that BMW should have gone with IMO. Hope this helps.
08 135i N54
- Vargas Stage 1 Turbos with Billet wheels - BMS Intake, BMS Charge pipe, AR DPs, Stock mids, berk race muffler delete - JB4 G5 Map 3 75 Meth Additive with RACE DME flash - MS-109 and 100% meth injection (Single CM12 nozzle) |
qcodec13.00 |
09-06-2011, 09:02 AM | #6 |
Rep 1,101
I have the 225/255 set up on the 264 wheel with Pilot super sports. No rubbing and a very nice tire. I got a continental flat repair kit (tire pump with the bottle of goop attached) from tire rack that I keep in me trunk. It fits in the netting on the side of my trunk.
qcodec13.00 |
09-06-2011, 09:12 AM | #7 |
Rep 508
No problem and no i dont have a kit for fixing a flat. I really should get one though. I keep forgetting about it. :-/
08 135i N54
09-13-2011, 01:02 AM | #9 | |
Rep 140
From their website: Use of this product on direct TPMS vehicles could also result in damage to the tire pressure sensor inside the wheel. http://www.tirerack.com/accessories/detail.jsp?ID=38 The Slime product seems friendlier to TPMS. http://www.slime.com/category/faqs/
2017 BMW 440i Blk/Blk-Blu Stitch | Auto | M-Sport | Nav
03-18-2012, 07:13 PM | #10 |
Rep 535
Drives: 18%E2%80%99 M3 Comp Pkg
ive been going crazy trying to find someone that has lowered their car with the stock m-sport wheels and put on 255's in the rear....
im lowered and the eibach springs... and looking to put new rear tires on and want to run 255's in the rear but dont want to buy and then end up rubbing... |
03-27-2012, 02:31 AM | #12 |
Rep 52
I have eaten through my rear tires after 6k miles (the potenza RE050A RFTs) and was also considering the MPSS. Great to learn that they will fit in slightly larger than stock configuration.
I have 3 questions though: 1. When you guys say "stock suspension" are you referring to the "standart suspension" or the 'm-sport package suspension" which lowers the car by 15mm over the standart suspension? Will the tires rub on an m-sport pkg car? 2. How much does the 255/35R18 MPSS tire stick out over the stock 264 wheels? Any upclose pictures? 3. Since my fronts still have plenty of thread left, I can replace the rears and another 6 months from now the fronts. Would I be crazy to go driving around spiritedly on twisty roads with the 255 MPSS rear and the original potenzas up front? I assume I would notice a significant increase in understeer since the MPSS are gripier and larger than stock on rear, while the originals remain up front. Thanks!! |
04-02-2012, 08:35 PM | #13 |
Rep 723
All 135i come with the sport suspension - whether no sport package, the sport package or the M sport package - its all the same suspension. BMW makes a performance suspension which is special order and not part of any package. That lowers the car about 10mm. I have the performance suspension on my 2011 135i with 225/255 bridgstone RE-11s on the sport (non M) package 18 inch wheels. No rubbing on my set up
qcodec13.00 |
12-18-2013, 10:20 PM | #14 |
Rep 43
Does anyone have an opinion on going with a 225/35 versus a 225/40 18" in the front? I'm thinking the 225/35 would be better as you avoid reverse rake, but everything I have seen is positive reviews for the 225/35 and no mention of 225/40.
Anybody have any input for 225/35 on the front? Thanks |
12-18-2013, 11:26 PM | #15 | |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.22] |
Stock 135i with factory wheel and tire fitment, positive rake |
qcodec13.00 |
12-20-2013, 01:56 AM | #16 |
Rep 199
Drives: F22 M240i
I've got a set of 264's that I plan on running in conjunction with a set of 225/40 and 255/35 tyres (either Hankook v12's or Goodyear Eagle F1 Assy 2's) as well as 10mm spacers up front and 12mm in the rear.
At some point the car will also be lowered on coilovers (looking at a set of BC Racing coils atm). Am I pushing my luck, should I expect to deal with some nasty rubbing if I don't start playing with camber? |
Tags |
135i, 264 wheels, fitment, recommendati, tire 18s |
