ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
      10-28-2014, 01:51 AM   #1
007M
007M's Avatar
17
Drives: '007 ///M Coupe & Boxster S
Exclamation Purchasing Wheels - Need Offset Advice
Looking to get:
f: 19x8.5 et 35
r: 19x10 et 20
Will this fit? I see some people have posted:
r: 19x10 et 25 and 19x10 et 27
I have no additional camber and no lowering, though I do plan to lower in the future if possible.
Thanks a TON!
GT
(z4mc)
      10-28-2014, 07:03 AM   #2
IN10SS
Drives: 2007 Z4M Roadster
fronts will be fine. Other people with more hands on will be a better source on this, but 10's are a tight fit on our cars. From what I've seen on other peoples' cars the ET to shoot for is 30-32mm, especially if you're thinking of going lower. I'd be worried it would stick out too far. I have seen one 10" with ET of 25mm. My personal opinion was it stuck out too far, but it worked. One trend I've seen concerning 10" rims is that most end up still running a 275 tire, the same size used on the more common 9.5 wheels. That cooled my quest for a 10" wheel during my search, as the 285 I wanted to run was too wide. Any chance your wheel of choice is available in a 35mm ET? Then you could use a small spacer to get a perfect fit.
      10-28-2014, 07:55 AM   #3
dubsesd
#dubspec
dubsesd's Avatar
Drives: G05 X5/ 2016 F80 M3 INDVL
19x 8.5 et 30 front and 19x 10 et25
This paired with 225/35/19 and 265/30/19 or 235 & 275
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow
instagram: @ dubsesd
      10-28-2014, 12:57 PM   #4
007M
007M's Avatar
17
Thanks as always dubsesd!
      10-28-2014, 05:35 PM   #5
dubsesd
#dubspec
dubsesd's Avatar
those are my specs with 225/265 pss
      10-28-2014, 06:04 PM   #6
007M
007M's Avatar
17
Man, that fitment is PERFECT! How much drop do you have on the coilovers? And are you running any extra camber?
Thanks,
GT
      10-28-2014, 06:30 PM   #7
dubsesd
#dubspec
dubsesd's Avatar
Not sure how much of a drop I have since I forget how it looked stock, but it's probably around 2.5" or so. My front bumper lip is about 2.5" off the ground. Camber is within spec and toe is set slightly out up front and in in the rear for handling which is what I wanted since this is a street car and not track. Tire wear is perfect
      10-28-2014, 06:46 PM   #8
007M
007M's Avatar
17
Dubsesd... you are awesome! I'm hoping to put 275's on the rears for the added traction because I'm running supercharged and could definitely use it.
Thanks again for your detailed help. I was able to send the pics on to the wheel company to get better fitment.
GT
      10-28-2014, 07:36 PM   #9
dubsesd
#dubspec
dubsesd's Avatar
265 will be more than adequate especially since a sticky tire in that size will run wider than a regular street tire
      10-28-2014, 07:46 PM   #10
dubsesd
#dubspec
dubsesd's Avatar
What supercharger are you running? I just drove a coupe with vf570 with cams, rods, and 3.91 custom build and polished differential with 275 PSS and I had no issues with traction. 265 r888/nt05 or similar will fit similarly but give you even more traction
      10-28-2014, 08:03 PM   #11
007M
007M's Avatar
17
Awesome! That is so good to hear. I have the vf570 as well. I haven't geared it yet but I do plan on gearing to 4.10. Eventually doing more but yea... What was your experience like driving this other vf570?
Tags
mcoupe, offset, wheel, z4mc
zpost
