      05-23-2011, 01:27 PM   #1
tareqt65
Drives: x5 4.4i
BMW X5 4.4i Diag Report (X431)
Someone please help me explain the CODES as follows :
The car runs perfect ... don't know whether I should be overly concerned .. is it just a sensor / cable issue or an ENGINE problem and that the car will suddenly stop ?? Would appreciate any help and also where (website?) I can understand these codes in more detail.
Thanks.
Code 140 Activation map cooling
Code 005 Oxygen-sensor heater before cat. conv., bank 2
Code 027 Multiplication. Mixture adaptation, bank 2, control limit reached
Code 5A Brief power interruption
Code 0A AUC sensor
Code 8 Tank sensor 1 (fuel pump side)
Code 21 Internal fault in instrument-cluster electronics (IKE)
Code 9 Fuel-level sensor 2(without fuel pump)
Code 0F Voltage supply, EWS control module
Code 13 Voltage Supply, EWS control module
Code 43 No code description
Tareq
