Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Post your wheel spacer setup!
Wheels and Tires forum Sponsored by The Tire Rack
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      05-04-2014, 11:58 AM   #1
ryanakata
Drives: '11 e92 335i AT
I myself have been searching through the forums and found many random threads on the topic of spacers but it would be easier if we just had one thread to lump it all into.
I myself have a 2011 E92 335i M Sport on 193 wheels and stock sport suspension. I also have two pair of BMS 15mm spacers that I'm scared to install in case they rub, and will probably send them back for some 8mm/12mm ones.
So post up your pics, and please try to include the following info.
Brand: (Doesn't really matter but we are all curious)
Size: Front / Rear (ex. 8mm / 12mm)
Suspension: Stock, H&R, etc
Rubbing: (None / on big dips / no with fenders rolled / yes with an elephant in the car)
And whatever else may be relevant that I'm leaving out.
Go!
2011 335i Coupe M Sport: Alpine White
      05-04-2014, 12:50 PM   #2
NJ Krish
NJ Krish's Avatar
Drives: Bmw 328xi 2008 Coupe
2008 Bmw 328xi  [10.00]
Bmw style 197 18's
Spacers 12mm front 15mm back
Stock suspension
No issues on rubbing unless I hit a big bump at certain speeds.
Current 2008 Bmw 328xi Coupe Sport N51 /w 3 stage IM | VMR 710 w/ Conti DWS | AA Tune Stage 2 | AA Signature Exhaust | Red Cyba scoops | Lux V4 | Euro-box mod w/ Silicone intake hose | Eibach pro kit w/ Bilstein Sport | Carbon Fiber Hood powerdome | Mtech Bumper w/ Akyrim CF lip
      06-26-2014, 09:12 AM   #3
335m
Drives: 08 e92 M3
Currently running stock 18" 189s on sport suspension:
12mm front - Perfectly flush / no rubs / highly recommended
15mm rear - Not flush / no rubs / putting 20mm on soon
Even though 15mm in the rear clears and looks better than stock the fact that the front is perfectly flush makes the rear look too far inset.
Sorry for lack of pictures, if I get the 20mm on before my coilovers i'll update this.
      06-26-2014, 09:24 AM   #4
ryanakata
Brand: BMS
Suspension: OEM Sport
Rubbing: Rear only on felt liners on huge dips, not bad.
      06-26-2014, 10:14 AM   #5
335m
Drives: 08 e92 M3
Originally Posted by ryanakata View Post
Brand: BMS
Suspension: Stock
^^ felt liners?
Also, you have the sport suspension not stock. ~0.6" lower than stock. Still, I don't think you should have any possibility of rubbing the rear with a 12mm spacer but maybe you have different tires? Weird.
I have 15mm on my rear and I jumped my car 6" or so (accidentally) a few days ago and when I came down I didn't rub anything. (except my rear passenger's head against the roof)
      06-27-2014, 09:48 PM   #6
ryanakata
Originally Posted by 335m View Post
^^ felt liners?
I have the OEM Michelin run flats. Maybe the tire is sllightly wider than yours. 15mm did rub on the metal inner lip.
Tags
spacers, wheel
