03-01-2010, 03:06 PM | #1 |
Rep 42
Halo lights for x6 M
Picked up my x6 M three weeks ago, and put on 1300 km so far. Now i want to make some small mods such as the Halo lights. Any suggestion? Brand? I know there are old threads about this topic but i couldn't find it. Many thx if anyone can link me to it.
Cheers |
03-01-2010, 03:51 PM | #2 |
Rep 17,017
Congrats on the car There are a few options out there, we carry the WeissLicht brand which is an LED based replacement that will upgrade the color to a xenon white.
03-01-2010, 03:56 PM | #3 |
Rep 80
Congrats on the X6M
Have a look at this - http://87.194.35.237/showthread.php?...hlight=umnitza I would recommend Umnitza for the Angel eyes upgrade! |
03-01-2010, 04:31 PM | #4 |
Rep 1,882
I replaced mine with white from E-92 Lighting.
http://www.xbimmers.com/forums/showt...lace+fog+light scroll down and you can see pics of someone that did it. |
03-02-2010, 02:09 AM | #5 |
Rep 42
thx all!! ill take a look at those. did all of you install the bulb yourself? im being honest im just n kid n i probably have no idea how to do it...
03-02-2010, 11:09 AM | #6 |
Rep 1,882
03-02-2010, 12:02 PM | #7 | |
Rep 42
haha im only going for the halo, x6m does have th fog lights. many thx |
03-08-2010, 07:20 AM | #9 |
Rep 129
Heres 1 dilemma I have been having.
Would it be wiser to replace the angel eyes with an LED or H8 type light? Ive heard the LED's arent as bright and they wont give error codes but what benefits would I get with using an LED vs replacing the stock bulb with a 6500k bulb from PIAA. What is the best kit to use, there are about 4 different brands out there and some input on what the best one is would be nice. I just want a clean crisp white light but Im skeptical if I should go with LED or changing the lightbulbs that power the angel eyes. Please help. |
03-08-2010, 07:57 AM | #10 |
Rep 399
03-08-2010, 12:10 PM | #11 |
Rep 17,017
The tradeoff between a Hyperwhite H8 Bulb and an LED is color vs. output. The LED bulbs will offer the best color (pure white), the hyperwhite bulb will provide the best output however is closer to a 4300k color temperature depending on the brand you go with.
03-09-2010, 10:58 AM | #12 | |
Rep 42
btw a local tuner company that i contacted is charging me $300 for HID 6000K . 0_o.... rip off much? |
03-09-2010, 03:24 PM | #13 | |
Rep 399
Is there a big difference in the HID with what you already have in the car as standard? |
03-09-2010, 03:39 PM | #14 |
Rep 17,017
$300 for an HID kit is pretty pricey, a solid HID kit can be had in the $150 range. Don't go for the cheap $50 kits, you will spend more replacing it.
03-11-2010, 07:19 PM | #15 |
Rep 44
I have literally tried 4 or 5 different H8 type bulbs (from 5500K to 7500K), different brands, and they were ALL the same. It's hard to tell the difference. The problem with ALL of them is that when you turn on your headlamps (HIDs) the current draw turns the halos into a pathetic weak color intensity. Now, with the LED's, the 3 W ones that split into two, the intensity stays the same but they are really weak especially in daylight and with the sun out. They look good at night and when your low beams are on... just my 2 cents
08-27-2011, 12:04 PM | #16 |
Rep 1
Jlevi StreetWerks is a fraud
hi i contacted jlevi for all the light upgrades on my X6M and they where very correct and responding my questions but when i had a problem these is the messsage i sent to theme and never got a response i tried to called theme but they hanged up the worst service ever:
i order the . 1 x WeissLicht PY24W LED Turn Signal Bulbs - Xenon White (WTSAAA2WY) = $99.00 but it says it is not compatible with my bmw x6m and i read that i need the 6OHM Resistor Set for LED Signals is it true. please let me know, because i order everything specificly for a bmw x6m 2011 and now im confused. becuase the do not fit right. thanks |
08-27-2011, 01:05 PM | #17 | |
Rep 1,882
I did the LUX H8 , see my pictures on this thread: http://www.xbimmers.com/forums/showthread.php?t=567217 |
08-29-2011, 11:49 AM | #18 | |
469
Rep 4,938
