      06-19-2019, 07:20 AM   #1
PeterQ
Drives: BMW X5 4.8
Rear hatch trim removal?
I need to check/clean up/fix the connections for my rear view camera, and to do that I need to get the trim off of the upper rear hatch. I undid the screws set into a couple of internal recesses, and prised open a couple of trim clips, but then it seemed reluctant to come away. I don't want to end up in the valley of the broken trim clips - are there other screws lurking there or should I just pry away and unclip the thing?
      06-19-2019, 09:08 AM   #2
heatmizr
Drives: E70 X5 50i M-Sport
Not sure myself but did you search Youtube? Some car shops have very helpful videos of stuff like this.
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e90 328i - sold
      06-20-2019, 08:26 AM   #3
omgboost
Drives: 2012 X5 35i
I've done it before. Not too hard. Make sure you remove the D pillar plastic panel first. If memory serves me correctly, the D pillar upper plastic panels are only held together with clips and some plastic insert. The lower part under the window has two screws and then you'll need to remove/unclip either the lights or the trunk close button. Other than that, just use some force and you'll get the panels removed.
Here are some instructions for an older X5 but should be similar to the E70.
https://www.pelicanparts.com/techart...eplacement.htm
      07-13-2023, 01:10 PM   #4
TexanDan
Drives: 2013 BMW X5 xi35
Thanks, that is helpful and will give it a try. One question - which part is the D pillar?
I did search for videos and didn’t find one for that.
      07-13-2023, 03:45 PM   #5
jbash87
2012 BMW X5 35d  [10.00]
2006 BMW M5  [10.00]
No. 3 and 4 in the schematic you posted on the other thread. Pillars are alphabetical from to back starting with A being the windshield pillar. For an SUV that puts the D pillar as the rear hatch pillar.
https://www.xbimmers.com/forums/show....php?t=2033248
      07-16-2023, 10:14 AM   #6
TexanDan
Completed! Thanks for the additional information, which made this fairly easy to do.
