      05-29-2018, 05:23 AM   #1
esevx5
Drives: X5
What happens if PCV is not changed right away?
What effects does it have on the car?
      05-30-2018, 12:35 PM   #2
philly42
Drives: X5M, Z3M
Which engine do you have? I think with the N54/5 it's an easy swap.
It depends on what issue you're having with the PCV system. Worst issue would be a clogged. This issue could be more or less common depending on the type of system.
Anyway, a clogged system can cause seals failing, more oil entering the combustion chamber and poor idle.
A leaking system can cause an oily smell, CEL, vacuum leak, failing emission test, poor idle
      06-06-2018, 12:29 PM   #3
jersey john
jersey john's Avatar
Drives: X5
Smile
Is there a DIY on the PCV system? How frequently should this be taken care of? Thanks.
If winning isn't everything, then why keep score?
I feel like every day is the Kobayashi Maru and my name's not James T. Kirk
      06-07-2018, 08:13 AM   #4
philly42
Drives: X5M, Z3M
Which engine do you have? What problem are you having?
here's a DIY on a N55:
      06-07-2018, 08:55 AM   #5
jersey john
Drives: X5
Fortunately, I’m not having a problem. I have 58k on the clock and want to make sure I take care of this girl. I ride her hard at times so I want to make sure I address as much as I can.
Thanks for the DIY.
