      07-30-2020, 05:51 AM   #1
NorthCountryGuy
The Quiet One
NorthCountryGuy's Avatar
1713
Drives: M6, E70, E71
2013 X6 M  [0.00]
2013 M6  [0.00]
2013 X5 LCI 35i Spo ...  [0.00]
2013 X5 LCI 35i  [0.00]
A Consistently Intermittent Cylinder Misfire Signal.
Guys,
The X6M is getting a Drivetrain warning and going into limp mode. This is what was found on the Foxwell at cylinder 5. Got it back to my garage. New Bosch plugs and coils from FCP all around. Still on occasion would get the same warnings. First switched coils between cylinder 5 & 6. Still a cylinder 5 warning. Then switched the plugs. Still a cylinder 5 warning.
Had to go to BMW for I had a sound system problem covered under warranty, so I had them plug in for the diagnostic work up. They said they couldn’t find anything. They said the fuel injector was fine. They said they put 80 miles on the car soft and aggressively but couldn’t find a thing. I told them to reprogram the car. After being parked at work he got these on the way home.
Where do we go from here ?
Thanks in Advance
Craig
2013 M6 Coupe Sakhir Orange Metallic / Sakhir Orange \ Black Merino - The Prince
2013 X5 LCI 35i Jet Black / Black SensaTec - The Horse
2013 X5 LCI 35i Space Grey Metallic / Black Nevada // Sport Pkg - Daughter’s
2013 X6 M Sapphire Black Metallic / Black Merino \ Carbon Fiber - Son’s
      07-30-2020, 07:10 PM   #2
quick
Drives: '12 X5M, '01 E55, '91 964 Trbo
Check the plugs but mine turned out to be the Injectors. Go to a different dealer and have them check for the Injectors.
How long have you owned this ///M and have the Injectors ever been upgraded to Index 12?
      07-31-2020, 11:25 PM   #3
1er_vert
Drives: 2007 BMW Z4 3.0si; 2010 BMW X6
How is that battery doing?
2007 BMW Z4 3.0si - Hellrot
2010 BMW X6 M - Space Grey
      08-02-2020, 07:19 PM   #4
denaliman
denaliman's Avatar
Drives: 2021 BMW X6M Competition
2013 X6M  [0.00]
Had the same issue. Injectors changed twice for same problem. Was intermittent both times. First time they changed all, second time they only changed one that was throwing the code.
_____________________________________
2021 X6M Competition, 2021 Audi SQ5 Technik, 2013 Audi S4
      08-03-2020, 06:02 AM   #5
quick
My local dealer following the BMW protocol had to change the plugs first beofre telling me it's the injectors. Friggen Monkeys couldn't diagnose the Injectors even though I told them I am just after changing the plugs.
Make sure you have BMW OEM plugs in the car before taking it in
      08-05-2020, 10:08 AM   #6
NorthCountryGuy
The Quiet One
1713
2013 X6 M  [0.00]
2013 M6  [0.00]
Yes, my plugs for both my M engines are BMW. The coils are Bosch.
As stated earlier all plugs and coils changed after the first misfire warning. When still got occasional warning, I flipped coils between cylinder 5 and 6. Still misfire on 5. Then flipped plugs between 5 and 6. Still misfire on cylinder 5.
My son was in a rush so he brought it to BMW north of Syracuse, and not the indy I would have used who was booked. I was told ‘the tech plugged it in and couldn’t find anything’.
I rolled my eyes and took the car. Is a 70 mile drive home. Began misfiring as he got home. Now the misfiring is more frequent. Will flatbed it to my indy who is a real mechanic.
Bear this in mind if you ever get stuck in Syracuse area.
      08-16-2020, 11:00 AM   #7
bmwx5er
bmwx5er's Avatar
Drives: 2017 X5m
I had a CEL for cyl 3 in my X5 50i, and the dealer changed the plug & coil, despite me telling the dealer that I inspected the plug and it was fouled up and smelling with fuel. I checked fuel rail pressure at idle and immediately after shut off, and noticed that the pressure dropped dramatically in bank 1 after shut off. Dealer will look at injectors now.
