The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > E90 320d 163kw Turbo strange behaving
      03-21-2024, 03:00 PM   #1
blaza
Drives: BMW E91
1a. Turbo variable was blocked and also there was excessive turbo play.
1b. Before turbo has been repaired MAF reading was 7g/s and fuel consumption was 7l/100km.
1c. After turbo has been repaired EGR was blocked and disabled by software.
2. Now, MAF reading is 13g/s (checked on two MAF sensors, one of then new).
3. Turbo works only in case if you, above 1800rpm, release gas pedal for a less then second and then hit pedal again.
Any help??
