Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Thermostat bad after 10k miles?
      03-16-2024, 02:51 PM   #1
skipper50789
Drives: E90 328i
2007 328i (N52, RWD) with 83k miles. Water pump and thermostat were replaced in April 2023 at 72k miles with OE Pierburg/Wahler combination.
Started having the fan run on high after short idles, and pulled "2EF8 - Map Thermostat, control" code out of the DME (no other codes).
Other than the fan running on high, I have no warning lights or overheating issues.
Is it really possible the thermostat went out again this soon, or should I have the issue diagnosed further? Thanks
