11-24-2016, 11:06 PM | #1 |
Rep 172
Troubleshooting light issue
Heya guys,
I'm having some dramas with my car 2012 e70 X5 M50D, specifically the turn indicators and high beam. Here are the symptoms, on startup one of these 3 things occurs: 1. Start car as normal. Turn indicators and high beam do not function. Manipulating the stalk as normal achieves nothing. Switches on the stalk still work as normal. 2. Start car as normal. Turn indicator will function but will not cancel. For instance I click left and it indicates but then I cannot cancel it or indicate right. 3. Start car as normal. All turn indicators and high beam function normally. There appears to be no common thing I can do, and each time I start the car one of the above 3 things will occur. Every other electrical/lighting item is working as per normal. I am hoping it is as simple as having a busted LCM, but I would be willing to hear anyones idea's on this? Cheers Dan |
