BMW 3-Series (E90 E92) Forum
Vanos 2A7C
01-30-2024, 02:57 PM | #1 |
Rep 9
Vanos 2A7C
2010 328i SULEV with N51 142k Miles. Just started having rough idle at startup, metallic noise from the front of the engine and 2A7C code.
I suspect that the vanos bolts are either loose or sheared, the vehicle is affected by the vanos recall (no remedy). I just dropped it off at the dealer to see if they'll replace the bolts under recall/warranty and I'll keep posted on what they find out. |
02-01-2024, 08:00 AM | #2 |
Rep 9
Dealer wouldn’t touch recall, basically did a courtesy check, read codes and stated engine was sludged and that was probably causing vanos codes. I’m going to seafoam the engine, do a couple quick oil changes and pull the vanos solenoids and give them a clean and see if it resolves anything.
02-01-2024, 04:23 PM | #3 | |
Rep 70
You might want to consider using a bore scope camera through the oil filler to see if you can check the presence and condition of the 8 bolts without having to remove the cover. You would need to remove the spark plugs to enable rotation of the camshafts via the crank pulley. |
02-11-2024, 09:57 AM | #4 |
Rep 9
Dealer just called, recall is available so going to bring it in. The code hasn’t come back since I cleaned the solenoids. I’m curious to see if I have sheared bolts.
johnnyorange58.50 |
03-09-2024, 03:05 PM | #5 |
Rep 9
Just an update. Recall finally available, 1 sheared bolt and two loose. Dealer replace and dropped oil pan to remove missing bolt. Once the pan was removed they found a considerable amount of non-Vanos related debris. Does anyone recognize what these parts are?
03-11-2024, 08:22 AM | #7 |
Rep 504
Is that the aluminum "head bolt" sealing the timing section of the head?
I thought this was an issue on early 06 n52 models... Can you confirm that all four bolts are there? There's one by the OFHG and 3 more below vanos sprockets. I paid a shop to drill them out and replace them after I found all four sheared off during valve cover job. I'm definitely one of a very few people who fixed this, it's probably fine to leave them as is. View post on imgur.com Last edited by Suvorovo; 03-11-2024 at 08:31 AM.. |
03-13-2024, 10:07 AM | #8 |
Rep 9
I think it might be a head bolt, car is running fine right now with no oil leaks. Original 2A7C code and rough idle are gone. I’m going to leave it as is until I get an oil leak then pull it apart and replace the bolts. Thanks for the confirmation!
Suvorovo258.00 |
