ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
      03-03-2024, 04:21 PM   #1
SepangZ4MC
Drives: Z4M Coupe
Some trouble removing battery M coupe
I'm having some trouble removing the battery. Seems like roadsters and coupes having slightly different battery mounts. There is a tab or clip along the bottom of the battery mounting area. I hope the photo shows up below.
There looks to be a plastic screw that holds this clip in place, which on mine is stripped but I am able to get a 8mm socket around it but turning it does nothing to loosen it up. Not sure if it's supposed to be removable. This clip is preventing the battery to be slid out. How do I get this off to be able to get the battery out or is there some other way to get the battery out without taking this part off?
      03-03-2024, 04:37 PM   #2
pungo
pungo's Avatar
No pic showing...
I don't remember anything preventing me from removing the batt... but it's been awhile.
      03-03-2024, 04:45 PM   #3
SepangZ4MC
Drives: Z4M Coupe
Originally Posted by pungo View Post
No pic showing...
Odd, I'm able to see it on my phone and laptop. Here's the direct link https://imgur.com/a/FNtNXWu
      03-03-2024, 06:08 PM   #4
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Those plastic screws strips pretty easily. It's similar to those used on the top plastic radiator cover. Try to get something to grab onto it and pulling it out as you turn it counter clockwise. I just replaced mine with a push expanding rivet
      03-03-2024, 06:22 PM   #5
pungo
pungo's Avatar
View post on imgur.com
Ok, after clearing cache, I see it. Anyway, yeah, the soft plastic strips easily. Use small flat blade behind the plastic washer and pry outward while unscrewing it.
      03-03-2024, 09:58 PM   #6
bosstones
Drives: o_0
I always tell myself I'm going to do that then remember after I put back in the stripped screw. lol
OP, I just ust a flathead screwdriver or trim/rivet tool to put pressure on it as I spin a socket on it.
      03-03-2024, 11:35 PM   #7
SepangZ4MC
Drives: Z4M Coupe
I tried a trim removal tool and turning it while prying but it wouldn't budge. I eventually just brute forced pulled it out with some pliers. This was way harder than I thought it'd be.
Anyone know the replacement part number of the screw + expanding rivet? Or what size plastic push expanding rivet to use?
      03-04-2024, 09:36 AM   #8
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Gosh - it's been at least 2 or 3 battery changes ago that I did this. But if memory served, I believed I used one of the wheel liner expanding rivet that I had on hand (P/N 51118174185). Alternatively, you can just buy a box of various sizes and find one that fits best, similar to this => https://www.amazon.com/GOOACC-Bumper...66&sr=8-5&th=1
      03-04-2024, 02:38 PM   #9
SepangZ4MC
Drives: Z4M Coupe
Thanks! I will give that a shot.
zpost
