M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      02-19-2024, 11:42 AM   #1
BMWSauberF1
BMWSauberF1's Avatar
Drives: 2013 BMW M5
Changed plugs, coils, and injector still having misfire on cyl 2
So as the title says I’ve changed the plugs coils and the injector on cylinder 2 however I’m still getting misfires once the car idles for a little while. It’s starts fine and idles fine initially but then you’ll slowly start to hear it develop a misfire within the first few minutes of idling. I was able to drive it for however long last week it wasn’t until i would go to turn the car back on that the misfire was there but now it starts within a few minutes of the car idling. What could it be. When it’s really misfiring bad it’ll also say that cylinder 4 is misfiring so what could be going on with that bank? It doesn’t always say that though.
      02-19-2024, 11:53 AM   #2
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
Did you reprogram the injector?
      02-19-2024, 11:54 AM   #3
BMWSauberF1
Drives: 2013 BMW M5
Yes I did on ista
I’m starting to think it’s either the fuel rail pressure sensor or HPFP on that bank
      02-19-2024, 12:01 PM   #4
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
On my other car, also German twin turbo V8, I was also getting misfires over a whole bank. Plugs, coils, nothing fixed it.
Turned out to be a bad oxygen sensor that wasn’t even giving a code. Maybe check those, they’re pretty easy to swap out.
      02-19-2024, 12:02 PM   #5
BMWSauberF1
Drives: 2013 BMW M5
Hmm ok I was just ordering a new HPFP and fuel rail sensor but I may as well throw a couple o2 sensors in as well
      02-19-2024, 12:04 PM   #6
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
You can also change them from the other bank if you don’t want to purchase new ones. See if the misfires are affected or not.
      02-19-2024, 12:06 PM   #7
BMWSauberF1
Drives: 2013 BMW M5
Good call I’ll go do that now. Should I just try both? Can’t I use ista to just view the values of all these sensors that way I won’t even have to touch them? But in feel like if a sensor was reading a weird number it would throw a different code that just a single cylinder misfire.
      02-19-2024, 12:07 PM   #8
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
Had the same issue one time. Turned out to be the coil pack was not seated fully, despite the clip closing. I would double check that particular cylinder.
      02-19-2024, 12:13 PM   #9
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
I would try both, you can do them in under 20 min if you have a thin walled O2 sensor socket.
I don’t think it would be if it was only one cylinder, but after you mentioned cylinder 4 as well it reminded me of this same issue I had.
      02-19-2024, 12:17 PM   #10
BMWSauberF1
Drives: 2013 BMW M5
Yeah I’ve removed and reseated that coil pack about 20 times already
M5Rick60142.00
      02-19-2024, 06:43 PM   #11
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
Damn. I hope you get down to the bottom of it.
      02-20-2024, 03:03 AM   #12
m760iM5
Drives: G12 M760i, F10 M5
Last year I was having a fairly similar problem for my 2013, but the idle was bad immediately after start up. This was a few months after doing the coils and plugs. My issue was one of the high pressure fuel pumps. I thought it was the injectors at first. Your issue seems a little different, so just food for thought.
m5post
