      07-28-2021, 11:34 PM   #1
Mayuiers
Drives: BMW X3, X5
Error code 2A7B (plus misfires) on N63
I had a problem with my 2011 X5 5.0 (error 2A99) and was able to get that sorted out by replacing the solenoids.
I'm now slamming up against a new error (2A7B - Vanos, outlet 2, cold start) and misfires on cylinders 1 and 4.
I've cleared the errors with Carly and they come back consistently.
The engine ran without misfires earlier, so I'm wondering if I made a mistake somewhere along the line.
Can someone please clue me in on what error 2A7B might point to?
Thank you!!
      07-29-2021, 11:23 AM   #2
Bengineer330
Bengineer330's Avatar
Drives: Le Mans Blue 2011 E92 M3
Like Sophisticated Redneck said in the other post have ISTA is just about required if you are going to DIY anything on the N63 engine because replacing some parts require a re-learn before it will operate properly and you will continue to have issues like you are having now.
The misfires 1-4 could very well be the crankcase ventilation hoses if you had to remove those. I hate having to remove those for anything because they are so brittle and a tiny hole can have you chasing your tail. Other than that check your intake hose clamp connections and make sure it all guetentight.
Here is a snippet that shows a Bleed and Re-Learn is needed after replacing any vanos component.
2011 E70 Xdrive50i M-Sport Black
2011 E92 M3 ZCP LeMans Blue
2006 E90 330i Silver - Donated after 410,000 miles
