03-31-2016, 10:16 PM | #1 |
Rep 94
Fuel System? related ticking...
This issue on my e70 X5M is driving me crazy...
A few months ago I started noticing that I would have some sort of 'ticking' noise that only occurs under specific circumstances...that is, when I am pressing on the gas pedal. When its at idle, or coasting, or any other time, the ticking does not occur...its ONLY when I am asking for fuel. (this is not the normal/expected, at idle ticking noise) I did not have this issue until after the injectors were replaced (Dec '15). Its been sitting with the dealer for the past 3 weeks getting other stuff done (AC Evaporator, air suspension, lower steering joint assy, and some other stuff they found along the way) but primarily to try and determine what is causing this sound...so far they have no root cause. It must be something in the fuel delivery system...Im guessing...as it only occurs when the gas pedal is pressed. It is a constant tick, it doesnt vary with speed. If it was in the cylinder head, I would imagine the ticking would be there constantly. I spoke at length with the shop foreman, who is a good guy that I have talked to many times, and was very honest and up front about how they can do certain things to remedy these kinds of issues, and can replace things within their level of approval, but obviously cant just drop a new engine in (although he would love to). Their next step is to replace the HPFPs, although they admit it is likely not the issue. From there, they are talking about pulling the cylinder head apart and replacing valve train components. Again, not sure how that could be the issue, given there is no ticking at idle. Just putting this on here, hoping maybe someone else might have encountered this issue themselves or has an idea what it might be...because right now, BMW is doing the 'try this and see what happens' game. Seems they don't really have a good procedure to troubleshoot noises of unknown origin. |
04-01-2016, 09:20 PM | #2 |
Rep 146
My suspicion is that the sound you describe is the fuel injectors going bad. I have a '13 X5M and noticed that around 20,000 miles the the engine started to produce a much more noticeable ticking sound, I describe it as a sewing machine. I have since had the S63 injector recall work done replacing all 8 injectors. Although the sound is not completely gone, it is considerably quieter.
I was told that the ticking sound was a by product of the extremely high pressures these injectors make and therefore some noise is considered normal. |
04-02-2016, 12:21 AM | #3 |
Rep 94
thing is, Ive had them all replaced recently...and 3 of them replaced twice. Seems like injectors is the weak link in the s63. Trying to get BMW to replace or even check them again is almost pointless, unless they have an actual fault to reference, since BMW wont let their service centers do much these days on their own - even when it appears to be common sense.
04-02-2016, 07:35 AM | #4 |
Rep 146
IIRC, I read a post about injectors being repeatedly replaced because of failure or imminent failure. My hope is that this latest recall is a sign that they have the injector design fixed.
My SA told me that the issue with the injectors can lead to total engine failure if not addressed. That's a really scary "wait and see" proposition if you ask me. I understand your frustration. You would think that the loud noise should be enough for them to further investigate given the history of the injectors-not to mention the alternative! |
04-02-2016, 03:47 PM | #6 |
Rep 94
04-02-2016, 03:47 PM | #7 | |
Rep 94
04-04-2016, 10:17 AM | #8 |
Rep 1,697
I can hear a pronounced tick, well beyond that of the injectors themselves. It comes and goes, but mine does it while driving and idling. I wrote it off as valve tapping after some limited research but I'm not sure if that's what it is and how serious it is.
04-04-2016, 11:38 AM | #9 |
Rep 97
I am having the same issue. It is really hard to describe because it comes and goes. Hard to replicate for the service advisor because it is sporadic. I have an appointment for some other items next week so will try to get them to look at it.
04-04-2016, 11:50 AM | #10 | |
Rep 1,697
Best way I found to describe it is, to me it sounds like a gas stove igniter but a little big quicker...suspected the spark plugs but no change after doing those. Please let me know if you find anything out. I noticed that some of the N54 guys have had the same issue, dealer diagnosed it as valve tick and deemed it normal. Doesn't sound normal... Last edited by mirob; 04-04-2016 at 11:59 AM.. |
04-04-2016, 01:19 PM | #11 | |
Rep 94
