      05-14-2024, 08:14 PM   #1
MagnusIsACat
Drives: e21, Z3, e46, e70
Crank no start, 11 codes, looking for a place to start
Hello,
2011 35i (122k miles) ran without issue until Sunday night, when it presented a "crank no start" condition. I am getting 11 codes.
277A - Hot film air mass meter signal: Electrical fault
2C58 - Charging pressure control: Switch-off as consequence
2C89 - Blow-off valve, activation: Short circuit to earth
2D52 - VANOS solenoid valve, intake, activation: Short circuit to earth
2D9C - Exhaust VANOS solenoid valve, activation: Short circuit to earth
2E4B - Exhaust flap, activation: Short circuit to earth
300C - Intake camshaft sensor, electric: short circuit to B+
300E - Exhaust camshaft sensor, electrical: short circuit to B+
332F - Terminal 87_2: No voltage
3400 - Engine oil pressure control valve, activation: Short circuit to ground
3492 - Engine-oil pressure sensor, plausibility: Pressure too high before engine start
Based on that I would say there's a short but I am hoping someone might know of a common issue with these codes and could hopefully point me in the right direction for trouble shooting.
Thank you!
Last edited by MagnusIsACat; 05-14-2024 at 08:21 PM.. Reason: Misspelled 87_2 as 97_2
      05-15-2024, 09:14 AM   #2
Attacking Mid
Drives: e46, e53, e83, e70
I would consider what work has been done to the vehicle recently and start looking there for something that got pinched, melted, etc.
AM.
      05-15-2024, 09:14 AM   #3
wcs531
Drives: E90 335xi / E70 X5d
Sounds like it could be a fuse:
https://www.e90post.com/forums/showthread.php?t=1658486
      07-12-2024, 10:43 PM   #4
Hamburger2021
Drives: BMW E70 X5
1992 325i  [0.00]
2007 X3  [0.00]
1997 328i  [0.00]
1997 528i  [0.00]
2008 x5  [0.00]
check the oxygen sensor wiring behind the throttle body. I drove my X5 to the side of my house to make room to work on my X3. I went to start it and nothing, Crank No start. I thought there may be a leak in air supply. I removed the Rubber boot with resonator and to my surprise there was a bundle of chewed up wires. My best guess: the wires are long and they fell down and got caught in front driveshaft. I repaired the wires and it started right up. I did make sure the connectors were secure and would not fall again.
