BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
      11-01-2008, 10:15 PM   #1
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Arrow Some E92 M3 Suspension Torque Values (Official BMW Specs)
UPDATED: Official BMW Specs!
Thanks to the help of a BMW tech and PencilGeek!
FOR REFERENCE ONLY! USE AT YOUR OWN RISK!
20 ft lb KW camber plate torx
      11-01-2008, 11:21 PM   #2
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
good info ... last picture, is it the rear part of the car ? is the 25ft-lb for the bolt that holds the rear shock ?
      11-01-2008, 11:30 PM   #3
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Correct to both questions.
      11-02-2008, 01:45 AM   #4
camaross305
camaross305's Avatar
135
Drives: 2008 M3
was 45 ft lb for the front and rear sway bar? Awesome info BTW way thanks for the extra effort!
      11-02-2008, 08:21 AM   #5
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
Excellent! Thanks for the very useful post. Appreciate your efforts.
      11-02-2008, 11:10 AM   #6
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Front only. No need to remove rear swaybar linkage.
      11-06-2008, 08:52 PM   #7
MDCTFTW
Drives: E92 DCT
DUDE!!!! You kick ass. I've been looking for this info forever! Where did you get the values from? Do you have torque specs for the rear install?
MDCT ... so you can drive and eat a hamburger at the same time.
      11-06-2008, 09:10 PM   #8
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
The last picture is the rear install. Couldnt really figure out one of them, but it was very tight, so tighten as much as possible.
      11-06-2008, 10:24 PM   #9
MDCTFTW
Drives: E92 DCT
So how did you come up with these values?
      11-06-2008, 11:09 PM   #10
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
      11-07-2008, 12:14 AM   #11
MDCTFTW
Drives: E92 DCT
LOL ... sorry it's been a really long day. Haha.
      11-07-2008, 01:18 AM   #12
swamp2
swamp2's Avatar
Drives: E92 M3
When is the darn full shop manual going to come out? We should not have to go through such measures to get torque values. Thanks indeed for the very useful post. Most thoughtful.
      11-13-2008, 05:01 PM   #13
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
UPDATED to include official specs!
      11-15-2008, 07:05 PM   #14
doba_s
doba_s's Avatar
i have a question ... on the last picture you are pointing out to #6 73ft-lb ...
isn't it suppose to be #7 ?
      11-15-2008, 08:56 PM   #15
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
aren't they the same? it's a bolt with a nut. you can tighten either one.
      11-17-2008, 12:12 PM   #16
MDCTFTW
Drives: E92 DCT
Nice, rzm3 ... now you can update your original post with the top nut torque specs.
      11-18-2008, 08:01 AM   #17
RRGOO7
RRGOO7's Avatar
360
Drives: GTR
Great thread....now we need ALIGNMENT SPECS!
      11-20-2008, 07:53 PM   #18
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
coming tomorrow!
      01-15-2009, 02:25 PM   #19
PunjabiM3
PunjabiM3's Avatar
Drives: M5 CS
Does anyone know what torque to tighten the front strut hat nuts (the ones that hold the front strut to the strut tower)?
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia
2020 BMW X7| Mineral White
2024 718 GT4 RS | Arctic Grey
      12-17-2009, 06:43 PM   #20
L-Altos
Drives: E90 M3
What does “64 Nm or 47 ft-lb” refer to?
OK, I’m a bit confused here. In the second diagram it shows “64 Nm or 47 ft-lb” pointing to the top of the strut assembly, yet it looks like the next diagram shows 37 Nm or 27 ft-lb pointing to the nut which goes on top of the shock. What does the “64 Nm or 47 ft-lb” actually refer to? Is that shaft of the EDC shock supposed to be tightened? I thought the shaft just spins in place and the bolt (37 Nm or 27 ft-lb) on top of the strut is what you are actually worried about tightening.
This might be obvious, but I need some direction here
      12-17-2009, 07:57 PM   #21
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
first shock diagram is the front, second shock diagram is the rear
      12-17-2009, 08:04 PM   #22
L-Altos
Drives: E90 M3
Yes, I know which is front and rear. So the bolt on the top of the front strut is 47 ft-lb then?
I guess I was confused by those last couple of posts
[I]PunjabiM3 Does anyone know what torque to tighten the front strut hat nuts (the ones that hold the front strut to the strut tower)?
rzm3 34Nm
[/I]
m3post
