TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Consistent O2 Sensor Error (2C32)
      10-16-2014, 11:35 AM   #1
coriolis14
Drives: 2007 E92 328i
Hi everyone -
First off, I'm kind of a noob when it comes to doing auto maintenance but this forum has been an incredible resource and has taught me how to do a lot with my car! I'd like to thank you all for your help!
Now to the problem:
I've been getting a consistent O2 sensor error for the past 4 months (error code 2C32) that is starting to get very annoying since I have to clear the SES light every month or so (currently using BMW Logger). I've taken the car into my indy shop a few times, but they claim the O2 sensor is working normally and just clear the code as I've done over the months.
My Car:
2007 E92 328i
N51 - 6AT
Odo - 68,000
I'm driving my car bone stock with no mods since it was new. I've done some research on the issue, but I haven't found anything relevant to the N51/N52 engine. Most of the other cases I've found were due to exhaust mods on N54s.
I have, however, had to replace my catalytic converters under warranty since my car failed a CA smog check last year. I'm not sure if this has to do with anything since the error (2C32) is for the O2 sensor before catalytic converter 2. I honestly have no idea what is going on at this point and neither does my indy (or so it seems).
I was hoping someone with a similar experience might have some insight on what is going on! Any advice would be welcome!
      10-16-2014, 12:31 PM   #2
jeguth1s
jeguth1s's Avatar
Drives: 2006 BMW 330xi
I assume you tried a new O2 sensor?
Bilstein+Eibach, UUC F&R sways, Powerflex bushings, PE+Supersprint 2nd cat delete, Euro Intake+Silicone Intake hose, SS Brake Lines
      10-16-2014, 12:33 PM   #3
coriolis14
My indy shop replaced it once already 2 months ago. I may have them try a new one again next week if I can't find another solution.
      10-16-2014, 12:43 PM   #4
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
Did they replace it with OE or OEM?
02 sensors are pretty delicate in general. Most people who have removed and replaced them(header installs, manifold swaps, CAT swaps) have had a failed sensor shortly after.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      10-16-2014, 12:46 PM   #5
coriolis14
My indy says everything they use to make repairs is OEM and I have no reason to doubt them (I've looked their maintenance/repairs done prior to this one and they check out OK with BMW labels/part #s).
Sounds like I should just take it back and have them try a new one!
      10-16-2014, 02:44 PM   #6
TheSt|G
TheSt|G's Avatar
OE=BMW Parts
OEM=Parts made by the BMW supplier
      10-16-2014, 03:11 PM   #7
thomas88162
Drives: E92 328i
It could be a vacuum leak. Does the code set more often while idling?
      10-16-2014, 09:39 PM   #8
MarkkyyMan
MarkkyyMan's Avatar
Drives: 2010 BMW 128i
Check for exhaust leak.
      10-17-2014, 05:54 AM   #9
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Your indy sounds a bit lame to me. Sorry but an answer of just keep clearing the light doesn't seem like a good answer. Any decent shop should use a scan tool to evaluate the performance of the O2 sensors and determine if they are functioning correctly. It could e the cats are defective again. A vacuum leak would show as a lean running condition. The car needs a complete scan under operation to check fuel trim, engine load, O2 operation, etc. Seems to me your car being in California and under 80,000 miles it is still under California emissions warranty. Maybe you should check in that and take it to a BMW dealer instead.
      10-17-2014, 05:04 PM   #10
coriolis14
Originally Posted by TheSt|G View Post
OE=BMW Parts
My mistake! My indy only uses BMW Parts (OE Parts).
My indy has performed a vacuum test each time I've brought the car in and each time it's come up with no results (there are no leaks in the system, per their tests). After the vacuum tests, they would then clear the code.
As for the catalytic converter going bad again - I originally thought this might be the issue, but the code (2C32) specifically refers to the O2 sensor before the cat. I'm not sure a bad cat would trip this sensor since it is located earlier up the exhaust stream. I'll have my indy look into whether the cat has gone bad again as well.
To be honest, I have been a bit troubled by this whole oxygen sensor issue with my indy...but they've always been honest with me in the past and seem competent. They haven't given me a reason to be suspicious or doubt their abilities. I've made an appointment with them for next week and will get back to you all with the answer they give me!
Thank you all for your input! I appreciate it!
      10-17-2014, 06:48 PM   #11
thomas88162
Drives: E92 328i
How does the area around your valve cover look? It IS a bit of a stretch, but a lot of oil seeping out around the gasket could contaminate the 02 sensor wiring looms, shielding or not.
      10-19-2014, 11:06 PM   #12
coriolis14
I checked around the valve cover, but there's no trace of oil (thank God).
I am getting a new error now though in addition to my original 2C32: 2C6C (O2 sensor after cat 2). I'm beginning to think there might be something wrong with the cat that BMW installed...
I'm not sure if I should keep driving my car (I use it as my DD ~50 miles round trip to and from work in mostly city driving). Anyone with a good reason think I should park it and borrow my sister's car until I get this looked at?
      10-20-2014, 12:46 AM   #13
thomas88162
Drives: E92 328i
If BMW installed it, there is a 2 year warranty on it. They will honor any repair IF it's the cat. It sure does sound like it could be, but then it is possible that something else caused it to fail again, like rich running, or a constant misfire for that matter.
      02-10-2017, 10:02 AM   #14
bmwfastlife
Drives: 2008 BMW 328i
I know this is reviving an old thread but did you ever get a resolution for your problem? I am having the same problem with my 2008 328i. Thanks
      02-10-2017, 11:48 AM   #15
Eagle1oh7
Eagle1oh7's Avatar
Drives: '11 328i Sedan
Have you tried MAF sensor? I had some lean codes pop up when my AFE box MAF gasket deteriorated causing air to be sucked in where the MAF is installed. Try spraying it down with MAF cleaner. It might be worth a shit.
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod
      02-11-2017, 12:10 PM   #16
PhaseP
Drives: 325XI
Well usually listen to the patient, especially when it has lots of CPU power
If the car is saying oxygen sensor, change the oxygen sensor.
      06-27-2018, 11:19 PM   #17
Illoosive
Drives: E92 328i 6MT
This has been happening to me for the past months. I've replaced every sensor it has said to replace. Codes just 1 keeps coming back 2C32.
Tags
e92, n51, o2 sensor, ses light
