      04-24-2021, 11:25 PM   #1
Cactus_BMW
Drives: '08 X5 3.0si
Center Console Rear Hatch Switch
I recently coded my E70, via Carly, to open the rear liftgate using the key fob. Shortly after, I discovered the rear hatch button on the dash board stopped working. The key fob and external button above the license plate both would still open the liftgate.
I've since reverted the coding settings to try to get the center console switch working again, with no luck. The other buttons next to the hatch button have remained working the whole time (PDC, DTC, HDC).
I don't know if this was just a coincidentally timed switch failure, or if something with the Carly coding caused this.
Does anyone have an idea as to what could be going on here, or what I could do to get it working again?
Thanks!
      04-25-2021, 05:45 PM   #2
SlowX6M
SlowX6M's Avatar
288
Drives: 2021 X6M, 2012 X5, 2018 M2
Thanks!
If i remember right, there are two modules that you have to code for it to work.
