04-23-2021, 09:03 PM | #1 |
Rep 376
Did I fry my batteries?
So I put my X6 on charge since it was parked for a couple weeks. It was charging around 45 mins then I smelt that rotten eggs smell so I quickly disconnected the charger.
I realized I did not select the 2amp setting so it was charging on regular setting. I let the vehicle air out for an hour or so and then took it for a drive and I didn't get any error messages etc. I removed the batteries and left them out for about 1.5 hours and then got them bench tested. The batteries both were still holding a charge so I'm wondering was that smell coming from the vehicle itself? I'm planning on leaving the batteries out and then taking them back to get tested on Sunday evening and see if they still hold charge. Any ideas as to whether the batteries are still okay? |
04-24-2021, 09:20 AM | #2 |
Rep 357
Well if the vehicle is fine then there’s no other thing that you can chase after looking for a fault. Smell the battery if the rotten egg is from the battery itself.
If anything, you had desulfate(sp) the battery. Congrats on adding more years to the battery. |
04-24-2021, 11:56 AM | #3 |
Rep 376
Are you saying that this process may have desulfated the batteries?
I was surprised when one of the batteries tested so high, I wonder if it was residual from the overcharge. In any case I'll have them tested again tomorrow just to be sure of the charge capacity. Does each batter serve a different purpose or do they both just power the vehicle? Would it be beneficial to install the higher rated battery in the position closer to the driver or passenger side? |
04-24-2021, 05:47 PM | #4 |
Rep 357
Higher battery ah will let you park the car for longer period of time because of bmw battery drain problem lol 😂. Both of my x3 and x5 couldn’t sit for more than 6 days without having a “high battery drain” message popping up.
04-25-2021, 09:33 AM | #5 |
Rep 376
I was getting the high battery discharge message as well. That was at the ten year mark with the stock batteries. I haven't had any issues since I replaced and registered the new batteries.
I'm headed back to the store today to test the batteries and compare the results with what was shown on Friday. |
04-25-2021, 10:29 PM | #7 |
Rep 376
The X6 50i has two batteries in the trunk.
So I took the batteries today to have them retested and one dropped by 16CCA and the other dropped by 27CCA. I had them removed from the vehicle since Friday afternoon. Both tested okay and I was able to get my hands on a noco genius 10 which has a 12V AGM charge mode. Both batteries charged and held a charge so it seems like they aren't damaged. But the odd thing is the vehicle still has that odour coming from it. Not a sulphur or rotten egg smell but it this odd smell I can't figure out. |
05-05-2021, 08:39 AM | #8 |
Rep 376
Can batteries off gas into the vehicle even if the vent tubes are both connected?
I still have this smell coming from the vehicle from the trunk where the batteries are. I recall when the batteries were removed for a few days, the smell was still lingering in the trunk but when I sniffed the batteries I couldn't smell anything. It's not a strong sulphuric smell but more like something is being fried, it's a weird smell I can't really put my finger on. If the batteries are still holding charge and have not bulged out etc, could they still be off gassing inside the vehicle? |
